Washing Machines Logo
Posted on Jan 24, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello there, I've buy zanussi fae 825 v washing mashine and now faced with problem. Mashine fill with water, then drain it off, then indicator of end of washing flashes three times, then goes out and again three times and so on. Could you help to me to find the reason of that problem Regards
Dado
Level 3:
Master:
  • Zanussi Master 511 Answers
  • Posted on Jan 28, 2018
Dado
Zanussi Master
Level 3:
Master:
Answers
511
Questions
0
Helped
482539
Points
1313
First: make rapid reading of alarms
How: the appliance is in normal operating mode (e.g. while the washing programme is in operation) than:
Press START/PAUSE and any one of the option buttons
simultaneously for at least two seconds: the LEDs first switch off,
and then display the flashing sequence corresponding to the
alarm condition.
The alarm is displayed by a repeated flashing sequence of the two LEDs: 1. END OF CYCLE indicator = indicates the first digit of the
alarm code (family)
2. START/PAUSE ? indicates the second digit of the alarm
code (number within the family).
After reading alarm code look down=
Could be:
E33 - Incongruence between contact closure of antiboiling and 1st
level of pressure switch.
Remedy: Pressure switch faulty; Current leakage from heating
element to ground; Heating element; Wiring faulty; Circuit
board faulty.
E35 - Water overflow.
Remedy: Water fill solenoid faulty; Leaks from pressure
switch hydraulic circuit; Pressure switch faulty; Wiring
faulty;Circuit board faulty
E36 , E37, E39 - Circuit board faulty
Dado
5 Related Answers
Anonymous
  • 1294 Answers
  • Posted on Dec 27, 2007
SOURCE: zanussi washing mashine
Plug off the wall. Open up behind, you will find a thin tube, maybe tranparent or black coming down from the control panel to the exit area (pump area) of your machine. Carefully disconnet this from above and blow into it, it should be free, if not clear it, if kinked or broken replace.
If this does not work, its your solenoid valve at the entrance point of your machine, top right, where the water is received. Just change this. If all works fine rate me please.
Anonymous
  • 156 Answers
  • Posted on Feb 27, 2008
SOURCE: whirlpool washer mashine # lcr7244hq1
no fuses bad control board
ginko
Ginko
  • 19396 Answers
  • Posted on Jul 13, 2008
SOURCE: oko-lavamat 6200 washing mashine does not rinse
When this happens it is usually a problem with the timer. By replacing the timer/programmer you should be able to fix it.
You can find parts here:
If you input model number on this website you will get replacement parts price.
Anonymous
  • Posted on Jan 06, 2009
SOURCE: performa spinning banging problem
I assume it is not balanced. Try putting sponges under the feet of the washer.
Bob B
  • 272 Answers
  • Posted on May 16, 2009
SOURCE: dear ladies and gentlemen,
You've answered your own question. E20 is a draining failure. Blockage in the sump hose, pump, drain hose or faulty pump. Clear the blockage or replace the pump if faulty and you'll clear the fault.
Mashine fills with water
check the program dial or settings. Put the machine off. then the water slot should close. If it does not close it is defect and you should ask a tech to replace it, or buy a new machine.
/Hello How do I wash a cloth and let drain the wahter and again prigramm the washingmashin to wash that cloth again
your nuts
a washing machine performs a cycle
wash rinse and spin
and thats that
you need a woman or man to wash again and again
Wshing machine keeps filling with water
You probably have a stuck fill valve. This is the part where the hot and cold water hoses connect. Just to be sure unplug the machine and if it still fills Remove and replace the fill valve assembly. Don't forget to unplug the machine and turn off both the hot and cold water supply valves. This is a rather simple repair.
Hello, I have WHIRLPOOL washing mashine model AWE 2214. Yesterday during squeezing, the masine stoped without noise, no indication buttons.I cheked everything, but the mashine no start. Please, help me!...
Go to www.washingmachine-manual.com/whirlpool-awe-2214.html for the handbook. Make a cup of coffee and have a read up. If that fails to help then its an engineer I'm afraid.
If you have a good diy friend have them check the belt drive if it has one? Be careful of electricity and water, they don't mix.
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Washing Machine does not fill up with water
THERE IS AN ELECTRONIC VALVE OR PUMP WHICH DECIDES WHEN AND HOW MUCH WATER IS ALLOWED TO ENTER THE MACHINE UNFORTUNATELY SOMETIMES IT HAS TO BE REPLACED I AM NOT 100% SURE BUT THIS MIGHT BE YOUR PROBLEM GLENN.....
Zanussi washing mashine zwf 1220 w water overflou
Why not just reduce the pressure at the inlet wall faucet. But dont reduce it too much or your clothes wont rinse well.............
1helpful
1helpful
2answers
Washing mashine repair
Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
