Question about Cameras
I cannot download my pictures from my polaroid x800 digital underwater camera. One user said to turn the camera on and press the picture button. My usb cable is where the batteries are so I cannot turn my camera on when the usb cable is plugged in the camera. Help.
    New Friend:
  • 3 Answers
1. Turn PC on.
2. Plug camera cable into Camera.
3. Plug camera cable USB end into computer USB port.
4. Turn on Camera... wait until camera show message 'USB, PC, Pictbridge'.
5. PC should be selected if not select by highlighting and press shutter button.
6. Press 'Shutter' button.
7. Window 'Autoplay' appears on PC. Select 'import' in Autoplay window.
8. Another window will ask you to name your picture folder. Give it a name.
9. The pictures download to the picture folder automatically.
10. Turn the camera off and disconnect cable from camera and from the PC
11. ENJOY!!
Posted on Feb 19, 2011
  • 2 more comments
  • TinyBrian Feb 28, 2011
    I am having this same problem. I am following the directions, but the "Autoplay" window never appears. I just uploaded from my regular digital camera today and the Autoplay window did appear, but nothing shows up for this x800 camera. Any suggestions?
  • Joe Blotnik Mar 01, 2011
    I have no ideas! I did this on the phone with my daughter and she said it worked for her. Since then she has used it several times and it still works. Sorry!!
  • bebishop Mar 17, 2011
    I am having the same problem did you figure it out
  • bonbonbeau Mar 25, 2011
    The PROBLEM is you CAN'T turn the camera on because the USB cable port is beside the batteries. When you open the compartment to hook up the USB cable there's no connection for the batteries !!!!! Who invented this camera??????????
SOURCE:
Polaroid x800 manual
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa ( http://picasa.google.com ).
Jan 27, 2014 | Polaroid a800 Digital Camera
The Flash is stuck to off on my Polaroid x800 camera. How do i fix this?
If Polaroid x800 flash doesn't turn ON - that is because of the picture mode (a plastic switch on one of the sides). In my case: mountains symbol - flash turns ON/OFF, flower symbol - flash is stuck to OFF.
May 23, 2012 | Cameras
User manual for Polaroid X800 digital camera
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support
heatman101
Sep 14, 2011 | Polaroid a800 Digital Camera
I can't get the photos from the camera to my computer. It's a Polaroid x800 camera.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ) on Windows or iPhoto on Mac.
May 22, 2011 | Polaroid Cameras
Purchased a Polaroid x800 camera and can not transfer photos to computer (and I have tried 3 computers - 2 running XP Pro and 1 running Windows 7). Upon connecting the USB cable it shows up as a removable...
Just did this with my daughter and it worked:
1. Turn PC on.
11. ENJOY!!
Nov 10, 2010 | Polaroid Cameras
POLAROID PDC 3077 looking for the user manual instructions to take a picture with the timer setting
There should be a button with a clock icon. Press it and you should be presented with choices for how many seconds you want before the pic is taken. Make your choice and press the shutter button...get in the picture.
Feb 25, 2010 | Cameras
Camera trouble
Here is the driver from Polaroid's website for your camera. i633 Driver It should allow you to download pictures from your camera.
Also, incase you need it, here's a link for the user manual. User Guide (English) It should describe in greater detail how to download your pictures.
Mar 09, 2009 | Polaroid i830 Digital Camera
Beep
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Cameras Logo
903 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
