GE JVM1650 1000 Watts Microwave Oven Logo
Posted on Mar 17, 2017
I have a JVM 1650SH01 Spacemaker Microwave oven that one day worked fine and next day I put a cup of water in to heat and ran the one minute button. The oven made a normal droning noise and after one minute the Water was still cold. I think the magnetron tube and or diode is gone or is there a fuse in this magnetron circuit> Everything else - timer, clock date and lock/unlock functions seem to work. Where in Fort Wayne, IN can I buy a new magnetron tube? Can it be fixed in place in it's position over the stove or does it need to be removed and put on the bench? Len 260 748-3192 GE JVM1650 1000 Watts Microwave Oven Problems by FixYa Free tech support for GE JVM1650 1000 Watts Microwave Oven and help with GE JVM1650 ... We see (and repair) this a lot. The problem is on the control panel, ...
3 Related Answers
robert landry
  • 96 Answers
  • Posted on Jan 22, 2008
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Anonymous
  • 43 Answers
  • Posted on Jan 28, 2008
SOURCE: Oven stops after a few seconds
I like the information you give.
If the unit will work with the control Panel at a 45 degree angle it tells me you have a loose connection. The 45 degree angle puts enough pressure on the connection to keep it completed. With the Control Panel in it's normal position, the loose connection Heats and Opens the connection. After it cools connection is again made until it Heats up again. Remember Expansion, Contraction. I do not believe you have a Magnetron issue!! A Magnetron does not know if the Control Panel is at an angle.
Can you hear a slight "Click" when the unit shuts down? If so this is a relay opening. When you say you replaced the Control Board. Was this the Control Panel PC Board, or was it the Cook-Relay Control Board? A Door Switch not making solid contact can do this. Is your Door latching down solid? Check for loose connections, not open LOOSE.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Feb 01, 2011
SOURCE: Magnetron will not run. I
You have replaced all those and still no go, well, In that case the main controller board is most likely faulty too. This is common, for the controller board and or power supply has been spiked.
We have a GE Spacemaker XL 1800 Microwave. There is dirt and moisture that has collected between the inside and outside glass. How can you clean this?
HELLO.
This is the solution to the cleaning issue.
1. Wipe the microwave inside and out with a soft cloth dampened with a warm, mild detergent solution. Rinse with a soft cloth dampened with plain water. Dry with a soft, dry cloth.
2. Put 2 cups of water into a 4-cup measuring cup. Place the measuring cup in the microwave, then heat on high for 5 minutes to loosen food particles that are stuck to the inside walls. Leave the measuring cup inside the microwave for 1 to 2 minutes, then remove and wipe the interior as in Step 2.
3. Remove the glass turntable and wash it in the sink with mild detergent or in the dishwasher. Handle carefully, as the turntable is breakable.
Thanks.
Counts down OK but not heating.... power says 10 (highest) all buttons work .. countdown ok but put a cup of water in and does not heat up.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Not heating up anything
Tat would be a magnetron problem. The magnetron is what provides the heat
Doesnt heat up
in a microwave, there is no heating element. There are microwaves that heat up the water molecules, they make them spin fast and that's what heats things up. Running it with nothing in it, you really can tell if it's not working by that test either, again, nothing to heat up. I would put in a cup of water, set on high for 3 minutes and it should boil, if not, get a new one for the price, why mess around?
4helpful
I have a GE Spacemaker model #JVM1650CH01 that keeps on shutting off everything after a few seconds. I have to rest the clock and month -year - date to try again.
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
My GE spacemaker JVM 1533BD microwave runs but will not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
stysty
1helpful
GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
GE JVM 2050BH001 does not heat but everything else works
hey! you told that everything working in your microwave oven! inside the microwave oven! transformer only producing heat! that transformer only fault in your oven! try to repair or change the transformer!!!!!!!
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
