Honeywell Professional Weather Station with Remote TE923W TE923W Logo
Posted on Nov 22, 2017
The rain gauge will not record the rain fall. It displays 0.00 on everything except last month. I now have it in the house have checked the batteries(they were fine) have cleaned it (it wasn't dirty) and have it and the main unit looking at each other. I have forced a search several times and nothing. what is the problem?
1 Related Answer
Anonymous
  • 43501 Answers
  • Posted on Nov 14, 2009
SOURCE: honeywell t8000c display is blank, unit doesnt run
I would say that you have one of two issues. Either your thermostat is bad or you do not have 24v coming from the heating unit. In this case the problem would be in the low voltage circuit of the heater. At the heater you should have 24v AC when you place an electric meter across the R terminal and the C or W terminal. If you have no vaoltage across the R to either the C or W then you have a bad transformer or a blown fuse in the furnace. If you do have voltage ther and also at the t-stat then the t-stat has gone bad, replace it.
1helpful
What is the rail fall amount for may in Ellenbrook Perth W.A
I finally found some form of daily records for perth
http://www.bom.gov.au/climate/current/month/wa/perth.shtml#daily
tip
How to measure rain fall when your rain gauge overflows
Most rain gauges that you will make at home will only measure up to one inch of rain fall. The problem with this is that if you live in a place where you will get more than one inch of rain your measurement if taken incorrectly will be very skewed. If your rain gauge has been constructed correctly you should have a fail safe in place.
When you construct a rain gauge you should have a measuring tube inside of an over flow tube. The meausuring tube will hold about one inch of rain fall, but when more rain falls the inside tube will overflow into the outer tube. To measure the excess rain fall you will follow a few simple steps.
Start by reading the inner tube of the rain gauge and then carefully empty the tube. Make sure that you don't pour out the water that has overflowed into the outer tube.
Once all the water for the measuring tube has been emptied carefully pour the excess rain water into the measuring tube. To get the most accurate reading try your best to not spill any water out, you can pour the water over a bucket to make sure that if you do spill any out you will catch it and be able to measure accurately.
If there is a lot of overflow you might want to measure a little bit of overflow at a time to get an accurate read. As you measure, write down the measurements and when you finish add up the values to get the reading.
The readings are done in inches so you have a reading that is 1.00 and has an overflow that measures up to .50 then the total read out will 1.50 inches.
on Feb 02, 2014 • Garden
Battery's are in correctly, still no transmit rain
It is possible that there is a thin film of dirt, oil, wax, on the contacts of the unit and also the batteries. I have seen this happen in the past. Try taking a Q-TIP and dipping it into some alcohol and wiping the batteries at each end along with the unit contact points. Let all contacts dry, and replace them into the unit without touching the ends. What do you have to lose? Good Luck Friend.
MONTH AND DAILY RAIN TOTAL ARE ALWAYS THE SAME EVEN AFTER A MONTH
Try going to the rain section, push the + BUTTON 5 times, and then on the 5th push, hold the button for 3-5 seconds and the guage will reset to 0.
I recently purchased and installed an Oregon Scientific Model WMR200A. The rain gauge worked for the first rain fall but it has not worked since. Today we probably got 3 inches of rain but it registered ...
Oregon Scientific has an FAQ webpage for your weather station:
http://us.oregonscientific.com/service/faq.asp?t=1&cid=2
There are several Q & As that are pertinent to your problem.
I hope this helped you.
Good luck from Detroit, MI.
Jul 19, 2011 • Vacuums
I cannot get the plastic shell back on the unit after removing to clear blockage in water drain/pan. Repeatedly hangs up, will not slide down last 1.5 to 2" to line up screw holes. Please advise...
  • Make sure the drain pan is in all the way.
  • The plastic housing gives many people trouble when reassembling. It has to be put on just so. Make sure you are clearing everything when sliding it back on.
  • This housing has to be fiddled with when reassembling a bit. It will go back on.
Regards, Tony
What does a simple rain guage consist of?
There are a variety of commercial rain gauges available on the market, however making a simple rain gauge is quick, easy and only costs as much as a plastic bottle. Chances are you already have everything you need to make this simple rain gauge, which is fun to construct, and interesting to use. Read on to learn how to make a simple rain gauge.
  1. Cut the top off of your plastic bottle. Cut about a quarter of the way down, to where the bottle begins to have a consistent diameter. Be careful to cut the edge as smoothly as possible, salvaging both pieces of the bottle.
  2. 2
    Remove the bottle cap and turn the top part of the bottle upside down, placing it into the bottom part. Connect the two halves with paper clips.
  3. 3
    Place the plastic bottle rain gauge in a location where it will easily collect rain without impediment from surrounding trees, plants or buildings.
  4. 4
    Help your rain gauge stand upright by placing it in a sand or gravel filled bucket. Simply make a hole in the sand or gravel large enough that half the bottle gauge sits into the pit. Use the gravel or sand to support the edges of the bottle gauge.
  5. 5
    Measure the amount of rain caught by your gauge by emptying the contents of the bottle rain gauge into a measuring cylinder.
Feb 07, 2011 • Home
My flash stopped working last week I got the camera in April It worked fine when I got it but .. No hits no falls no rain it is carried in a pouch and has unlimited battery supply..
My flash stopped working last week I got the camera in jan It worked fine when I got it but .. No hits no falls no rain it is carried in a pouch and has unlimited battery supply..
Hard Drive Problem
This has happened to me once. I unplugged it overnight and plugged is back in and everything (Except for the for the DVD that was being written when it malfunctioned) Worked fine. I suspect that a Capacitor is going bad but it’s still working (for 4 months) and I will put off any real trouble shooting until it fails hard.
Top Honeywell Measuring Tools & Sensors Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Honeywell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
