JVC HD-52Z575 52" Rear Projection HDTV-Ready Television Logo
Keith Boyer Posted on Jan 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I2c stop accidentally entered in service screen on option 3. how do i get back to default setting also trying to reset hdmi interface in this screen
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Jan 31, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470250
Points
19564
You must get your ON before make any settings on it. Please check the power line first ( fuse and cable). Use the volt meter to check voltage on your tv
  • Muntejaya Ginting
    Muntejaya Ginting Jan 31, 2011
    Thanks a lot for your rating!!!
MPC305spf cannot login
Doesn't http://www.fixya.com/support/t16807144-set_ricoh_aficio_mp_c305spf_factory help?
Samsung Plasma PN64D7000
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
How can I enter service mode on a Konica C7000? It is in fault mode with a code of C3501
This reset procedures reset the copier fuser the hot part if the code comes back aftyer procedure DO NOT DO AGAIN IT CAN CATCH ON FIRE RUINING A PERFECTLY GOOD DAY!!!!!!!!!!! Get a tech out to look at it
1. Be sure that the ordinary operation screen *1 is displayed.
Press [Utility/Counter] button.
2. "Utility screen"
On the Operation panel, press the following buttons.
Stop ? 0 ? 0 ? Stop ? 0 ? 1
When the CE password has been set, entering the password is required to enter the service mode.
3. "Service Mode Menu screen"
The service mode appears.
*1 Default is [MACHINE] screen.
go to
03 System Setting
• 01 Software DIPSW Setting
set the DIPSW 3-1 to 0.
why you do it once then get a tech out to look at it. DIPSW3-1 is set to 0 before defective parts are fixed, it may cause fire
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Both hdmi ports dont work Vizio 50" model P50HDM
Reset Vizio TV default:
1. Press the MENU button on the remote. The on-screen menu is displayed.
2. Use the Arrow buttons on the remote to highlight the Help icon and press OK. The Help menu is displayed.
3. Highlight Clear Memory (Factory Default) and press OK.
4. Enter your parental control passcode. If you have not yet set up a parental passcode, enter the default, 0000.The TV displays, "Are you sure you would like to Restore Defaults? This will erase any custom settings."
5. Highlight Yes and press OK. The TV displays "Memory is being cleared. The TV will reset shortly."
6. Wait for the TV to turn off. The TV will turn back on shortly afterward and the Setup App will begin.
Blue on the screen of the tv
Try to initialize it!
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight "MEMORY INTI", arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Reset cisco airnet 1130ag
There are 2 ways to reset the access point.
Using the MODE Button
Follow these steps to delete the current configuration and return all access point settings to the factory defaults by using the MODE button:
1. blank.gifOpen the access point cover
2. blank.gifDisconnect power from the access point (the power jack for external power or the Ethernet cable for in-line power).
3. blank.gifPress and hold the MODE button while you reconnect power to the access point.
4. blank.gifContinue pressing the MODE button until the Ethernet LED turns amber. (approximately 2 to 3 seconds). Then release the button.
5. blank.gifAfter the access point reboots, you must reconfigure it using the web browser interface, the Telnet interface, or the access point console port.
Using the Web Browser Interface
Follow these steps to delete the current configuration and return all access point settings to factory defaults using the web browser interface:
1. blank.gifOpen your Internet browser. You must use Microsoft Explorer (version 5.x or later) or Netscape Navigator (version 4.x or later).
2. blank.gifEnter the access point IP address in the browser address line, and press Enter. An Enter Network Password screen appears.
3. blank.gifEnter the username Cisco in the User Name field.
4. blank.gifEnter the password Cisco in the Password field and press Enter. The Summary Status page appears.
5. blank.gifClick System Software. The System Software screen appears.
6. blank.gifClick System Configuration. The System Configuration screen appears.
7. blank.gifClick the Reset to Defaults button.
Note blank.gifIf the access point is configured with a static IP address, the IP address does not change.
8. blank.gifAfter the access point reboots, you must reconfigure it.
My ps3 has no picture but has sound
you can try this..
leave a testimonial if it works.
if it doesn't write back and we will try another idea I have.
From the PS32_bing.gif main menu:
1. Settings->Sound Settings->Audio Output Settings
2. Change it from HDMI to Digital Out (Optical). I do NOT have optical hooked up on my PS3, so if you have it hooked up, you may want to unhook it.. probably shouldn't matter.
3. I left what was defaulted: "Linear PCM 2 Ch. 44.1 kHz" and 48kHz
4. Right on the D pad (X selects/unselects options) to move to the next screen.
5. A confirmation page, hit X to Enter, saving the changes.
6. Start up a game, you shouldn't hear any sound (as expected)
7. Exit the game, then go back to Audio Output Settings and switch back to HDMI. I selected "Automatic" for "method for setting the output format."
8. A confirmation page, hit X to Enter, saving the changes.
9. Start up a game, you should now hear audio with your game (once again).
My issue I believe was caused because I had been using a different TV2_bing.gif for a while. Somehow, when I switched back to my original TV, the settings did not automatically reset back.
Good Luck!
Rastor needs adjustment on 60v500a
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
4helpful
3answers
Ricoh IS200e Web interface password
default login: scanner
default password: password
Washing machine defaults to clean washer option
Sounds like user interface board. Try unplugging the machine, press power button for 3 seconds, plug machine back in and try again. If this does help, it will probably be a temporary fix. The user interface board is the one mounted directly to the console.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
