Question about Dell PowerEdge 840 (becwmk1_2) Server
Dell Poweredge 840 shutdown automatically - Dell PowerEdge 840 (becwmk1_2) Server
  • Dell Master
  • 2,386 Answers
Hello
This error mostly comes with the failure of processor fan, overheating of processor shuts down the system due to processor's protection. You need to check the fans and replacement is recommended.
Hope this helps
Posted on Jan 31, 2011
SOURCE:
Hi i wanted to upgrade my poweredge 840 and use it for gaming, but it wont let me disable on board gpu. screens just go black, when invidia pluged in. can you help? or is there a MSI motherboard with
The problem that you are having is that the unit you are trying to upgrade is a SERVER, and not a desktop PC. There are notable differences in how servers are built. One is that they are not all that concerned with graphics and graphics performance, since they normally operate "in the dark" and are often accessed remotely. I did some research on the Dell site and saw a comment about your problem in one of their forums. I provide the link below. It should be informative.
Graphic Card not working in Dell Power Edge 840 Server
Jan 02, 2015 | Dell PowerEdge 840 (becwmk1_2) Server
I cannot get the Dell PowerEdge 840 to recongize and of my HDD in the Raid array.. Trying to install the OS but tells my on HDD is detected
Then you need to get into the BIOS of the PERC RAID controller and inspect the state of the physical/logical volumes. Reboot the machine and watch for the prompt after the PERC5/6 RAID controller loads it's BIOS.
Considering this a null issue given the age, though...
Jan 21, 2014 | Dell PowerEdge 840 (becwmk1_2) Server
Orange blinking light on 840 PowerEdge
Take all 84 of your servers to a service outlet.
Nov 16, 2012 | Dell Pallet Of 48 Poweredge 840 Intel Xeon...
Why red light blinking on dell poweredge 840
Check your power supply or the power supply source (outlet or UPS unit) as well as the power cord. Your system power source is not at the correct amp, voltage and may need replacing.
Good Luck.
C2Solutions
Feb 14, 2012 | Dell PowerEdge 840 (becwmk1_2) Server
My Dell PowerEdge 840 will not allow me to install Windows 2000 Server software. Evidently, the 840's graphics card does not contain the drivers for Windows 2000 Server. Is there a solution?
I am not sure where you got your information but I just checked Dell's website and they have Windows 2000 drivers for your server which include the video driver.
http://support.dell.com/support/downloads/driverslist.aspx?os=WNT5&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PWE_P4_840&hidos=WNET&hidlang=en&TabIndex=)
If you are still having a problem then you should call Dell support. Every Dell server has lifetime free phone support.
If this helps please vote for my solution.
Sep 29, 2009 | Dell PowerEdge 1600...
Will only power up for 5 to 10 seconds and then shuts off. I have to unplug the power cord to repeat.
It sounds like an overheating problem. The newer cpu's have a thermal shutdown sensor that automatically shuts down system if it senses a temp that is too high. Common solution would be to check your cpu/ chassis fan and see if they are working. If not replace.
Dec 20, 2008 | Dell PowerEdge 840 (becwmk1_2) Server
Dell PowerEdge 1600SC Server problem
I had the same thing happen in a 600SC about a month ago.
Replaced the memory, and it fixed the problem.
It did the same hang. Would run fine for any where from a hour to 3 hours, and then quit (hang). And I got the same message. Talk to them and it was a short in the memory module, so some times it would read the entire stick, other times it would "not see it", and that would lock the OS.
Sep 03, 2008 | Dell PowerEdge 1600SC Server
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
Dell PowerEdge 840
reinstall your server it will resolve your porb.
Dec 03, 2007 | Dell PowerEdge 2600 Server
Dell PowerEdge 840 (becwmk1_2) Server Logo
570 people viewed this question
Ekse
Clive
Clive
