Lexerd - Pandigital novel 7" color multimedia eReader (Black) TrueVue Anti-Glare Laptop Screen Prote... Screen Protector kit Logo
Posted on May 30, 2017
Hallo wij hebben inmiddels 4 weken geleden een ebook gekocht merk Pandigital Novel Wij kunnen er alles mee doen behalve wanneer je een boek wilt bestellen en overgaat naar betaling. En je klikt Ideal betalen aan dan kom je niet verder. Doen wij dit zelfde met de laptop dan is dit geen enkel probleem. Maar wij hebben geen ebook gekocht om via onze laptop boeken te gaan bestellen. Ook de leveancier van ons ebook komt tot op heden niet met een oplossing. Met vriendelijke groet, J.Bisschop
3 Related Answers
Anonymous
  • Posted on Feb 05, 2011
SOURCE: did the firmware update on pandigital novel white
I have the exact same problem. Also it deleted all personal info and then I saw it said panditial color and mine is white. Seems like a phone info not ereader. Hope someone can help us.
Anonymous
  • 109 Answers
  • Posted on Mar 02, 2011
SOURCE: I have the Pandigital novel
No you cannot repair this unless you want to take the time to try and find a used screen on ebay and try to assemble the new screen yourself. You are better off buying a new ereader.
Anonymous
  • Posted on Mar 25, 2011
SOURCE: my touch screen cracked on
Pandigital never repairs or replaces the touch screen. They told me to throw it away. Think 100 times before buying that stupid product.
3answers
Mspa lite hot tub control panel comes up with E1 fault
we had the E1 error on our mspa after a water change. solution was a reset for us. plug in power, briefly press test and wait 10 seconds. unplug the power and wait for 10 seconds. plug in the power again and wait 10 seconds after which the reset button is pressed. then press the temperature button on the controller and briefly switch the air button on and off. after this the thermostat did it again. we were relieved that this worked, we had already searched the whole internet. this solution was copied from a model of lay-z
Jun 18, 2018 • Pool & Spa
Gaarne toezending activeringscode
Cees, Deze site probeert mensen te helpen met technische vragen. Daarvoor is het belangrijk, dat er een duidelijke vraag wordt gesteld. Ik denk dat het voor jou niet moeilijk is om te zien welke GPS je hebt, maar voor ons is het een compleet raadsel.
Mogelijk heb je een apparaat gekocht, dat je na aankoop moet activeren, maar dat moet je dan toch echt doen op de site die hoort bij het merk dat je hebt gekocht. Meesal staat het gewoon op de doos of in het handboek in de doos. Met site naam en wat je allemaal moet invullen voor de activering.
Als het niet om een nieuwe GPS gaat, maar als je zelf een kaart ergens vandaan hebt gehaald, moet je echt andere wegen bewandelen om achter de activering te komen. Daar zijn vooral in Nederland veel sites actief, die, weliswaar tegen een geringe vergoeding, alle mogelijkheden ter beschikking stellen om in oudere apparaten nieuwere kaarten actief te maken. Maar het past niet op deze site daar al teveel over te zeggen. Dus zelf even google gebruike.
Als je een technische vraag hebt, is het handig als je zoveel mogelijk gegevens geeft over het apparaat, het operating systeem en over de situatie waarin het is, alsmede hoe het in die status of situatie is gekomen.
apparaat : merk en model
OS bijvoorbeeld Windows XP of Mac OS 9.6 Of als het om een GPS gaat, bijvoorbeeld welke boot loader en welk systeem erop draait.
Sorry dat er na zo'n lang verhaal geen oplossing is, maar ik heb goede hoop als je iets technisch hebt we je wel kunnen helpen.
Oct 01, 2014 • GPS
Silvercrest lcd tv 19111
Doen jou wonen om haar? Heeben enn?? Doos
Een twee dree vier vrif zis zeven acht negen teen??
Twaalf dirteen tv ist how laat is het?
Sce website
Hallo Norman.
Ik weet niet of je even tijd hebt mij te mailen?
Ik ben een jeugdvriend van jou zo'n 20 jaar geleden. Ik zou het fijn vindenals je me eventjes zou kunnen mailen ik zou graag overbepaalde omstandigheden uit onze jeugd samen met jou bespreken. Mijnmailis r.maas79 at gmail. Groet Ricardo Maas
2answers
Fit my Acer Aspire 3000 ?
akku Acer Aspire 3000 100 percent compatible with you Compaq Presario CQ61. I bought two Acer Aspire 3000 batteries from http://www.pcakkus.com/acer-aspire-3000.html two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Ik heb een dell dimension 2400 windows xp uit 2004. In de setup controle loopt hij vast met gevolg een blauw beeld scherm.en doet vervolgens niets meer.
I am using google translation to explain this to you in your language.Please read below:
Als u krijgt blauw scherm, dan is het een probleem met windows xp. U moet een reparatie-installatie van Windows XP met behulp van de schijf te doen aan u met deze computer of voor een fabriek reset te gaan. Houdt u er rekening mee dat als je een fabriek reset al uw persoonlijke bestanden, zoals Word-bestanden, muziek, films, foto's zullen worden verwijderd en uw pc zal worden als wanneer je een nieuwe pc. Alles zal worden hersteld naar de fabrieksinstellingen.
Als u een reparatie-installatie zul je er rekening mee verliest uw persoonlijke bestanden.
Als u nog meer vragen laat het me weten.
Dank u.
2helpful
Waste ink near full
I'm having the same problem. Lots of solution for resetting the printer, but none of them helping me to lead me to the absorber itself inside the printer. It seems to be a lot of work and disassembling half of the printer! Looking on internet I haven't found any answer yet.
As I am living in The Nehterlands I'm looking for solutions in Dutch. One solutions discribes disassembling another Canon printer. This could possibly help. I'll paste the text below. It's dutch, so you'll have to translate it.
Wishing you succes with this matter!
Dutch text:
Wat te doen bij de melding 'Afvalinkt bijna vol'?
Onderstaand verhaal geldt voor de Canon SmartBase MPC200; voor andere Canon
printers geldt ongeveer hetzelfde, met uitzondering van de reset-procedure (zie
hieronder).
Oorzaak
Onderin de printer bevindt zich een langwerpig, dik vloeiblad (een soort spons van
vilt). De overtollige inkt, bijv. de inkt die gebruikt wordt bij het reinigen van de
koppen, wordt afgevoerd naar deze spons. Als deze spons bijna verzadigd is,
verschijnt bovenstaande melding. Dat is ook nodig, want als je gewoon door zou
kunnen gaan, zou de spons geen inkt meer opnemen, en op een bepaald moment zou
je merken, dat de printer zou gaan 'lekken'. Geloof me, dat wil je niet meemaken.
Printerinkt is gemeen spul!
Canon
Het lastige is alleen, dat Canon nogal moeilijk doet over deze melding. Zij hebben
maar één oplossing: opsturen en het probleem door hen laten verhelpen. Kosten: ruim
€ 100,-!!! Toen ik dat van de telefonische helpdesk hoorde, reageerde ik met: "Dan
kan ik beter een nieuwe printer kopen!" De telefoniste was dat eigenlijk wel met mee
eens.
Zoeken
Vervolgens ben ik gaan zoeken op het internet. Wat je daar niet kunt vinden, bestaat
niet, tenslotte... Toen merkte ik al snel dat ik niet de enige was met dit probleem.
Iedere eigenaar van een Canon-printer krijgt er na verloop van tijd mee te maken.
Helaas was er geen kant-en-klare oplossing voor mijn printer, maar door de
beschrijving bij andere printers kreeg ik wel een idee over de oorzaak van het
probleem en wat ik eraan zou kunnen doen.
Oplossing
Over de oorzaak heb ik al geschreven. Over de oplossing gaat het nu. Die gaat in twee
stappen:
1. De vilten spons schoonmaken.
2. De printer resetten.
Dit is een vies werkje. Doe een schort om en gebruik huishoudhandschoenen! Inkt in
je kleren gaat er niet meer uit en op je handen duurt het een hele tijd!
De spons ligt helemaal op de bodemplaat onderin de printer. Je moet dus een beetje
handigheid hebben en niet bang zijn om een schroevendraaier te gebruiken.
Schroef eerst de beide zijkanten van de printer los. Die zitten elk met twee schroeven
vast (één aan de voorkant en één aan de achterkant).
Verwijder dan het toppaneel (met de scanplaat). Die zit vast met twee schroeven aan
de achterkant en drie aan de voorkant (deze drie zitten aan de onderkant van het
bedieningspaneel). Let op: zodra je het toppaneel verwijdert, merk je dat die op drie
plekken vastzit. Op één plek met een schroef (gewoon losdraaien) en op twee plekken
aan de elektronica. Trek die twee punten voorzichtig los. Je kunt het toppaneel nu
opzij leggen.
Dan moet je de printplaat verwijderen. Maak eerst alle 'draden' voorzichtig los. Kijk
goed hoe het vast zat, om het later weer te kunnen bevestigen. Maak dan de printplaat
los (4 schroeven). Verwijder daarna ook de metalen plaat, waarop de printplaat vast
zat.
Je bent er nu bijna. Het bovenste deel van de kast (voor zover die er nu nog staat) is
op de vier hoeken met schroeven bevestigd op het onderste deel van de kast. Je moet
misschien wel even zoeken, want ze zitten diep weggezakt. Schroef ze los.
De bovenkant en de onderkant zijn nu los van elkaar, maar nog wel met draden en
elektronica aan elkaar verbonden. Maak die verbinding niet los, dat is niet nodig.
Doe nu het schort om en de handschoenen aan!!
Je kunt nu bij de bodem van de kast komen. Daar zie je de spons, die zwart is van de
afvalinkt. Kijk eerst hoe de spons erin zit, voordat je die eruit haalt.
Maak de spons voorzichtig schoon. Niet wringen en zo, alleen uitspoelen en eventueel
induwen om de inkt en het water eruit te halen. Ga een flinke poos door, totdat er
alleen nog schoon water uit de spons komt.
Hang de spons een paar uur te drogen in de zon. Gebruik daarna een föhn om ook het
laatste beetje vocht eruit te halen, zodat de spons weer kurkdroog op zijn plek gelegd
kan worden.
Zet de zaak nu weer in elkaar. (Als je het net zo doet als ik, houd je twee schroefjes
over, maar mijn printer doet het nog steeds prima. )
1a. Niet schoonmaken maar bestellen...
Sinds kort weet ik dat je de spons ook kunt bestellen. Dat scheelt een boel pruts- en
schoonmaakwerk.
Je kunt de vilten spons, die uit 2 onderdelen bestaat, bestellen bij ETB (Electronic
Trading Benelux).
Bel naar 0165-850500 en bestel de volgende artikelen:
HC1-0795-000
QA4-0213-000
Toen ik ze bestelde (in maart 2006) waren de kosten voor deze 2 onderdelen samen
maar E 1,04!!
Deze prijs was wel exclusief btw en verzendkosten. Maar omdat ik het samen met
andere producten bestelde, had ik daar geen last van.
Als je nu de printer weer aanzet, kun je merken hoe dom het apparaat is. Hij heeft niet
in de gaten dat de spons weer schoon en leeg is. Dat moet hem nog verteld worden.
Op het internet kon ik daar geen geschikte procedure voor vinden, dus ben ik maar zo
brutaal geweest om Canon op te bellen. Eerst deden ze afwerend (ik moest de printer
opsturen), maar toen ik vertelde, dat ik het grootste deel van het werk zelf al gedaan
had, kreeg ik een technicus aan de lijn, die me stapsgewijs uitlegde wat ik moest doen.
De stappen laat ik hieronder volgen:
1. Zet de printer aan
2. Druk op de (langwerpige) menuknop
3. Druk op de meest linkse ronde knop (Copy)
4. Druk op de ronde knop rechts daarvan (Scan)
5. Druk twee keer op de meest linkse ronde knop (Copy)
6. Druk op het min-symbool (links van OK); het scherm zegt nu: 'Test mode'
7. Druk op OK
8. Blader met het plus-symbool (rechts van OK) tot het scherm zegt: '#8 Printer
Test'.
9. Druk op OK
10. In het scherm staat nu: '8: Printer Test' en daaronder: '- 8 - 2 +'
11. Druk 1x op het plus-symbool; in het scherm staat dan: '- 8 - 3 +'
12. Druk op OK
13. In het scherm staat nu: '[0]: Ink Count'
14. Druk op OK
15. Druk op de knipperende oranje knop om die uit te laten gaan.
16. Mogelijk werkt dat niet. Trek dan de stekker uit het stopcontact.
17. Wacht even. Doe de printer weer aan.
18. Als het goed is, ben je nu bevrijd van de irritante melding over afvalinkt.
Succes!!
Help ons aan een nederlandse gebruiksaanwijzing van de KYOCERA
we hebben inmiddels een gebruiksaanwijzing gevonden,zodat onze vraag gewist kan worden.
gerard en willeke
Korg C-15 S concert piano
ik heb 20 jaar geleden een korg c 15 piano gekocht voor 5000 nederlandse guldens.
we zijn tot nu toe nog steeds tevreden met de piano.
sinds een paar dagen wil hij niet meer hard spelen ,je hoort hem alleen nog maar in de verte .
alles is goed aangesloten ,schuifje staat op zijn hardst en er staat ook stroom op ,want het lichtje brand .
kan iemand mij vertellen wat ik daar aan kan doen ,ik wil hem nog niet kwijt ,misschien is het maar een kleinigheid.
vriendelijke groet
mevr v haasteren
Top Lexerd GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Lexerd GPS Expert? Answer questions, earn points and help others
