Question about Maytag MAH8700A Front Load Washer
I own a Maytag Neptune 8700 Washing Machine. It regularly registers a E3 error during. After reviewing service bulleting # TDL-0078A-B from June 2006, I thought that it could be the wires since it usually cuts out during the high vibration spin cycle. Unfortunately, I could not figure out how to remove the terminal block to fully check the leads per the service bulletin (Is it by the screw pictured below - I was unable to loosen it with various Philips head screw drivers?). I was able to push in the wires slightly and this temporarily relieved the problem but the connection loosened after another 7 loads. Any suggestions on how I should proceed?
SOURCE:
SOURCE: Maytag Neptune stops during rinse cycles
I think the cold side of your water valve is stopped up at the screen. Just take your hose off at the machine and get the crud off the screen in the valve. It only does it in rinse because you have cold rinses. When warm water comes in, it will fill just fine because the hot water is not blocked
Posted on Sep 07, 2007
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
  • 209 Answers
SOURCE: maytag neptune front loading washer
purely based on the vague information you have given, this could sound like the drum bearings and the fact that it has been neglected for so long has resulted in serious damage to your machine, note to all, never continue to use machines making noises, it can only get worse and do mare costly damage, after all the problem could have been a very inexpensive fix problems on this and any other site, to be fixed by messages (without actually seeing the machine) can only be fixed - or advice can only be given based on the details that are given if you say my machine just stopped then you will not get an answer will you? engineers can help sort out lots of problems without seeing the machine if we are given the right DETAILED information, no matter how silly it sounds, so before you shout and complain at others, have a thought about what you are going to write sorry its bad news but i hope i have helped
Posted on Oct 02, 2007
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Posted on Dec 06, 2008
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
MY MAYTAG NEPTUNE FRONT LOADER WASHER KEEPS SHUTTING OFF AND THE E3 ERROR MESSAGE IS ON THERE
Transmission or clutch assembly not engaging due to going out or slipping. even bad door switch
Sep 20, 2014 | Maytag Washing Machines
I have a maytag fav6800awq it has an e3 fault code what does this mean?
Never see the e3 error code
Service Manual for the FAV6800A/FAV9800A page 13 Google ""16022808.pdf"" to find.
error codes start on page 13. Any other info on the failure. Do you know what part of the machine wash cycle you were in with this error code.
Aug 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag laundry neptune front loader washer MAH6700AWW. It is showing a E3 code error. what can we do for that
Hi, the E3 error means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code comes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 16, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune washer will not get up to speed in spin cycle error code E3
E3 means that the control board is detecting current going to the motor, but the motor won't turn properly. If the error code somes up all the time as soon as you press the power on button, then it means your control board is bad and reading incorrectly. If it only happens during a cycle, then you need a new motor unfortunately.
Jun 09, 2010 | Maytag Washing Machines
Not finishing the spin cycle and have a code that says dc
here is a website you can view a bulletin on the error code DC pertaining to your washer
http://fixitnow.com/wp/2009/06/11/e3-and-dc-error-codes-in-maytag-mah6700-8700-and-9700-washing-machines/
May 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Error code e3
Hi;
This is the tec bulletin from maytag, read it if you can't understand it
you should call a appliance tec.
http://www.servicematters.com/maytag_library/docs/TDL-0078A-B.pdf
Feb 06, 2010 | Maytag Neptune Washer
E3 keeps poping up
Hello leggettelect,
The e3 code has to do with the Hall Sensor. This is a sensor that looks at motor RPM. There have been some issues with the wire harness or the harness connectors being loose. You can also get the code if the sensor itself is loose and cant read the motor RPM. Here is a link to a tech bulletin from Maytag explaining it in more detail and has some pictures so you can see what to check. Hope this will fix your problem.
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
May 12, 2009 | Washing Machines
Maytag may8700aww washer with e3 code
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
May 05, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag MAH8700A Front Load Washer Logo
59 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
