Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
Posted on Jan 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My water pressure is very low from the original install is there a way to adjust the faucet to allow a better pressure flow
Anonymous
Level 3:
  • Master 463 Answers
  • Posted on Jan 31, 2011
Anonymous
Master
Level 3:
Answers
463
Questions
Helped
182596
Points
1499
Your issue could be caused by the water restrictor in the shower head. To know for sure, remove the shower head and then turn the water on.
Very tough water restrictions have manufacturers using plastic water restrictors in the shower heads.
Although you are not supose to, some shower heads can be taken apart to modify, or remove the restrictor.
I hope this helps you.
Just had a Moen dual handle Broadwalk lavatory faucet installed. Water pressure was fine in old one but the new one has low water flow. How to remove the flow restrictor?
remove and check the screen in faucet for debris as to that your valving is probable much smaller than old one and not going to be able to adjust
tip
I bought and installed a new 3 valve cold water valve for my W2277HB. Initially...
If you are getting the IE fault code or error code from your LG washing machine then you need to know why you are getting that code and what do you need to do to fix the problem.
This error code is caused when the washing machine does not fill up with water in about eight minutes. The washing machine gives its self eight minutes to reach the right water level. If there is a problem that keeps the water from entering fast enough the machine will shut down and give the IE error or fault code.
The most likely problem that will cause this fault or error code is that the water hose screens are plugged with dirt and debris. Most all washing machines have some type of water filter in the hoses or in the machine at the entering point for the water. Dirt and debris will build up in these filters till in restricts the water flow enough to cause this problem.
The other cause for this error is if you happen to reverse the hoses. If the cold water hose is on the hot side and the hot is on the cold side it can also cause to alarm. If the filters look clean then check the location of the hoses and make sure that they are properly connected.
Check that the water valves where the hoses connect to the domestic water supply are on completely. Some valves are difficult to tell if they are completely on or not.
If you need to reset your washing machine fault or error codes you can do this by unplugging the machine and then holding the start/pause button for five seconds. Then plug the machine back in and the code should be removed.
http://www.fixya.com/support/r4342015-lg_washing_machine_ie_error_code
http://www.fixya.com/support/r4341906-ue_error_code_lg_washing_machines
http://www.fixya.com/support/r4341798-lg_washing_machine_oe_error_code
http://www.fixya.com/support/r4341643-lg_washing_machine_error_or_fault_codes
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
on Jul 01, 2010 • Washing Machines
The water pressure is severely low. How can I improve the flow?
From what are you experiencing low water flow?
is it from an outdoor faucet?
indoor? Kitchen or bath?
bathtub or shower?
or do you have some other kind of spigot that is low flow?
Has it always been low flow?
Or, did it just start showing this symptom?
Is Low flow present at all faucets? Or just the one?
many questions... Because you were not specific! We would like to help, but we can help you better to get to a solution when the questions are not so basic!
If you have always had low water flow, throughout, then your supply is restricted at the main. If just one termination point, then it is possible the restriction is right there at that faucet,
Apr 09, 2015 • Plumbing
I have a brand new moen muirfield high arc faucet with low pressure at spout but good pressure at side spray what can i do to get better pressure at spout
clevine336-
The design of a hand sprayer is meant to provide a higher pressure spray (the smaller outlet size means greater velocity in the water coming out of the sprayer head). That said, there could be something constricting the water flow in your faucet. If you unscrew the aerator on the end of the faucet do you get better pressure? Is the screen in the aerator clogged with sediment or mineral deposits? If this is the case you may have water requiring periodic cleaning of the aerator.
Hope this helps.
Regards,
DIYpro
Our rheem pronto tankless rutg-74xp red light will come home indicating hot water and stay on about 2 minutes and then turns off we have turned off and back on and let water run for 5 minutes and will come...
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
List of causes MIGHT include one of following:
Bad household circuit breaker that powers electronics, or loose wire inside outlet where tankless plugs in.
Tankless fuses and control board.
Water flow rate too low. Minimum .8 gallon required (depending on model)
Tankless inlet filter clogged.
Household aerators clogged at faucets.
Crossover at single-handled faucet
If installed, there can be crossover at mixing valve.
Faulty household check valve, including check valve on re-circulation system if that system is installed.
Restriction in household water line, such as clog at elbow.
Unequal pressure in household hot and cold lines, caused by restriction in hot line. When single-handled faucet turns on, the cold water pressure is higher so hot does not flow and tankless will not turn on.
Loose wire connection inside tankless.
Unit temperature set too high.
Unit temperature set too low.
Water temperature is very hot coming out of tap, so more cold is added, but that reduces amount of hot water flow, so tankless turns off because flow rate is too low.
On some tankless, if water is preheated by solar or other indirect source, the burner will not activate.
High mineral content in water > delime tankless yearly
Misaligned temperature sensor
Low gas pressure. Wrong type of gas. Undersized gas line.
Too many faucets on at same time.
Faulty tankless water valve. Water valve stuck.
Fluctuating household water pressure, for example MUD and PUD district water pressure problems or water well pressure.
Faulty household pressure reducing/regulating valve if installed.
Faulty household pressure tank, if installed -or- pressure tank needs to be installed.
Hi just moved in new home love it but the water pressure in kitchen is very low but the two baths i have the water pressure is fine can you help me please
One thing you could try is to remove the aerator at the end of the spout on the faucet, Turn water on and see if pressure is any better. If so the aerator is got something in it restricting the flow.
You also can remove the dime shaped flat in the aerator to increase water flow. It looks like a dime with a hole about 1/8" in center to restrict the flow to about 1.6 gpm. Remove it and reinstall aerator and check water flow
Most of the times when cold and hot side of faucet.It would be the first thin to check being you have good water pressure at other faucets. They catch debris and the flow slows down from the faucet's. Check out supply lines and faucet for a blockage if this doesn't take care of the problem.
Check out this web sire for a parts breakdown of parts in faucet. Check out installation and rough in sheet for information on faucet below.
http://www.needplumbingsupplies.com/Kohler-Kitchen-Sink-Faucets.asp?id=3628
1helpful
Looking for tank psi trying to get better water psi out of the shower and taps
Every faucet and shower have a water saving restricter in them. Remove them from the shower head and end of the faucets.
They are about the size of a dime and with about 1/8" hole in them in which water flows out. So the flow is getting restricted from 1/2' flow to this giving you a water saving about a 1.5 gpm.
Below is some more information for the web site please check it out for further help.
http://www.inspectapedia.com/water/Poor-Water-Pressure-Diagnosis.htm
Poor water pressure just at certain plumbing fixtures? poor cold water pressure, hot water pressure, or both hot and cold water pressure or flow that is observed just at some plumbing fixtures in a building while flow and quantity are good at others suggests that the water flow or pressure problems are local to certain runs of supply piping or to the specific fixtures. Check the following first:
  1. Clogged aerator or strainer on sink faucets - clogging by dirt, debris, corrosion, can significantly reduce both hot and cold water flow at a sink where the strainer needs cleaning or replacement. Unscrew the strainer from the faucet and turn on the water - if the fixture pressure or flow is much better you've probably found the problem.
    Look at the aerator/strainer: inspect it, clean it, perhaps soaking it overnight in vinegar to remove corrosion and mineral build-up, or just install a new aerator/strainer.
Jun 04, 2010 • Plumbing
Restricted flow old kitchen faucet
While not always the case, low flow is usually caused by a plugged aerator. The aerator is the device that softens the water flow as it comes out of the faucet. Unscrew it, remove it, and clean any debris out of it.
Before you put it back, turn the faucet on briefly to flush any other debris out and to see if the water pressure is better. If not, there could be a cartridge (if equipped) issue of some piping problem.
2answers
I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
Mar 08, 2010 • Plumbing
2answers
Just installed shower and faucet in bath tub when you turn the water on the water comes out of the faucet and shower head. When you pull the lever for just the shower the water cuts off at faucet and comes...
Verify the height from the shower valve to the Shower head, the instructions specify the correct distance if it is too short the pressure could be getting up to the shower head.
Perhaps the water pressure it too high at the valve not allowing all the water down the faucet outlet, there are set screws on the sides of the shower valve to adjust the water allowed in the mixing chamber.
Something is restricting the water flow to the faucet, creating enough pressure to send some of the ater supply up to the shower.
I hope some of these ideas help
Mar 01, 2009 • Plumbing
Top Moen Plumbing Experts
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
