If the trucks engine rev'd up when you first put the gas pedal down, but didn't go anywhere then it was probably in neutral (not drive as you thought). If it was in drive and still didn't go anywhere but engine still rev'd up then its a transmission issue or PRNDL switch at the side of the tranny. I can't see anything relating to the gas pedal by NOT reving up the engine when it was pressed down. I wouldn't suspect a throttle cable issue. Check the tranny fluid while truck is running in park, see if the fluid is badly burnt or low on the dipstick. If it looks good I would have the PRNDL switch checked. (Park Reverse Neutral Drive and Low) switch.
