Yes the balance ring is supposed to be filled with glycol..... these washers cannot runn bulky loades or single articles of clothing.... if the load your running is not coating the drum evenly the all the weight is going to be on one side of the tub which is going to spin vigrously uneven,,,
also cabrio washer top lids are very slanted which means u cant level the washer by using the top of cabinet .... put level on each side use split of cabinet top to bottom of cabinet as your straight edge for placement of level ... theb level front to back and left to right and check other side ... if it checks out level....then take a clear cup fill 3/4 with water and place 2 feet infront of washer and start washer spin cycle if you see any ripples in water in cup while washer is spinning the reinforce floor joist under washer ...
