Brother MFC 420CN All-In-One InkJet Printer Logo
Posted on Jul 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to clear error code
I have a brother 420cn mfc , it has a 07 error code can you help me to clear it
kate Winfield
Level 2:
Novelist:
Habit-Forming:
  • Brother Expert 62 Answers
  • Posted on May 21, 2019
kate Winfield
Brother Expert
Level 2:
Novelist:
Habit-Forming:
Answers
62
Questions
36
Helped
76856
Points
265
Stage 1: Check Your WLAN Access Point/Router
Initially, you need to check your WLAN passage/switch that has the WPS or AOSS™ image. You can take clear comprehension about by review the beneath picture so as to affirm your WLAN passageway/switch is bolstered WPS or AOSS™.
In the event that stage 1 does not work, at that point pursue to the following step2.
Stage 2: Configure Your Wireless Settings
You ought to arrange your Brother Printer for a remote system/setting by utilizing programmed remote mode (WPS or AOSS™).
Ensure that you should work both your Brother Printer and the WLAN passage/switch.
https://www.brotherprintersupport247.com/blog/how-to-fix-brother-printer-error-ts-07
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jun 05, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
Helped
1869
Points
10
Unplugging and leaving the printer powered down for ten to fifteen seconds can work wonders. Try it; you might like it.
7helpful
2answers
Error code 4F on my printer MFC 420CN, is there anything I
Error Brother 4F
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
30helpful
2answers
I have a brother mfc-420cn. I am getting a unable to clean messa
Do you mean "unable to clean"?If it this follow this instruction.
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If numberis over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Brother MFC 420cn "Cannot Init"
This is the Head Error 41
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
5helpful
Error code A7 on brother mfc-420cn
Hi there
(A7 One-line feeding timeout error. )
Brother Error Codes RAM clear (most models)
Quickly press function * 2 8 6 4
Display should read maintenance
Press 0 1 for a full ram clear, or 9 1 to retain user data
Display should read reinit for a few moments then redisplay maintenance
Press 9 9 to exit the maintenance mode
Other maintenance mode switches:
01 ram clear (see 91 below)
02 scanner initialize (feed a white sheet, then a black sheet)
05 white level
09 print test
10 modify soft switches
11 print configuration list
16 panel test
19 CML test
20 signal test
21 tonal test
23 filter RX
54 scan edge
55 scanner area
66 test print memo
75 display drum life (if enabled on laser models)
76 reset drum life counter (laser models)
91 parameter initialize (user programming remains intact)
95 protection
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Brother mfc-420cn
this is two ways for screen this error: 1. mechanical problems 2. absorber counter full If you don't hear ubnormal sounds from your printer, you must clear counter for absorber.
2answers
Brother MFC-420CN
press menu then start b/k copy then fourtimes arrow-up (tel.index). machine will be in maintenance mode. press start b/k copy: What two digit error code does the machine display? Post here again.
To leave the maintenance mode press 9 then 9.
Error message on my Brother MFC-420CN
press menu then start bk copy then fourtimes arrow-up button. Machine will switch to maintaenance mode. You may have to press start bk-copy. The machine will display an error code.
Error code starting with 4 is always a defective print head which needs replacing (except error 46: new waist ink tank needed).
In case it is another error code plz post here again.
2answers
Mfc-5460cn
Please tell us what machine do you really have:
Is it a mfc 420cn or a mfc 5460cn?
Did you have a paperjam before getting the error?
This might be due to the paperjam.
Ill try to give you some more help but need more info...
10helpful
2answers
Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Brother MFC 420CN error message DF
Did you had lightning strikes or a high tension the days before? DF means that the faxmodem which is placed on the pcb is in disorder. The pcb has to be changed (sparepart is more expensive then a new mfc!)
Norman Weimar
Norman Weimar
k24674
