Nerf Nite Finder Logo
Posted on Jan 31, 2011
My Nerf Nite finder laser doesn't work, we have the batteries in and in the correct way. Any ideas please????
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Feb 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
7020
Points
28
Here's one--
Although I am not completely familiar with the internals of the NERF NIGHTFINDER I have a good idea what is wrong.
Sometimes factories screw up, etc...
Lemme get to the point.
The circuit operating your light (if you don't know what that is look it up and find out) is probably not connected. Open up the laser and look online at what the internals look like. Make sure that the circuit is complete.
That's all, email me at [email protected] for more info on modding and nerf guns.
STEVEN N MILLER
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 07, 2020
STEVEN N MILLER
Contributor
Level 1:
Answers
Questions
0
Helped
636
Points
Put it apart and follow the laser wire it might not be in the right place or there is corrosion some where.
2answers
In need of batteries for my Skil stud finder and laser for my Skil saw Laser?
Question edited for clarity, wrong type of 'skill' > 'Skil'.
Question moved from 'Laser Airlines'!
Model Numbers are needed for definitive answer, but just generic descriptions given so generic answers supplied.
It is the same as the Zircon?
https://www.google.com/search?q=Skil+stud+finder+battery+replacement
Skil Laser
https://www.google.com/search?q=Skil+saw+laser+battery+replacement
I have a nerf nite finder that when i **** it back it fires without warning do you have a soulution
That sounds like an internal mechanism issue, parts of the plastic on the inside could have worn down, causing the spring to slip and fire the bullet off.
3helpful
2answers
Hi my nerf mavric works fine until u shot it i took the air riesters out and know when i try to shot it makes a big noise and nothing els
The same happened to me you have turn the turning part that holds the bullets right before the triger goes back all the way you have to turn the part with you fingers a little bit.
1helpful
How do you turn on the light
to activate the light you need to insert two AA batteries into the handle at the bottom.When you have done that hold the trigger without loading any darts and it will light up.
8helpful
Nerf Vulcan won't auto-fire
I had the same problem with two guns out of the box. Turned out that the dividers in the battery tray kept the batteries from touching each other on some brands of batteries. Remove the dividers and should work. You can verify this by measuring the voltage on the two terminals of the battery pack.
Jan 04, 2010 • Nerf Toys
4helpful
Our new Nerf Vulcan EBF-25 won't auto fire. We tried changing the batteries to several sets of new ones, but it still won't work. Any thoughts?
You might have a bad motor in your nerf vulcan. If you want the aouto fire to work than you may have to get a new Vulcan.
Nerf controller
Hi Rayjdawg,
Check the battery pack on the back of the controller. It's been known to not have good contact at times. I would also try changing the battery. Good luck. :)
Top Nerf Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Nerf Toy Expert? Answer questions, earn points and help others
