Hi, this could be as a result of mall adjustment, or simply clutch plates stuck together as a result of the machine standing, normaly running the machine and using the clutch is enough to cure this,otherwise you may havee to remove the clutch plates and check for worn or distorted plates, it may also be that the clutch basket is worn not alowing the full release of the plates, check for exsess ware in the form of groves cut by the plates in the outer and inner basket.
thanks for using fixya
paul
