Zenith B27A11Z 27" TV Logo
Posted on Jan 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Please give me z card i need some so bad please!!!!!!!!!!!!!!!!!!
matt martin
Level 3:
  • Zenith Master 1,259 Answers
  • Posted on Jan 30, 2011
matt martin
Zenith Master
Level 3:
Answers
1259
Questions
12
Helped
297137
Points
3635
You may have one of two problems. A vertical one in which you may have horizontal lines across the top of the screen. Or one bright centered horizontal line. The fix here is to resolder the vertical IC and replace the capacitors near and next to the vertical IC. The second problem would be the dead set. In this case , the power supply will need reworked. You will need the following components. Replace the powerline regulator STR53041, the regulator N4923 and capacitors of these values, 25 volt at 100 MF and a 35 volt 22 Mf. these components are near and next to the regulator STR 53041. Now,next to or in front of the flyback transformer there is a small cap at high voltage...I believe this one may be a 200 volt at 1 or 2.2 Mf. replace this, and the other capacitor near two heat sinks on the edge of the board in front of the vertical IC is a 25 volt 220 Mf cap that is also dead. It has been a very longtime since I have repaired this one. But the information, will get your TV up and running again! Find an electronic hobbiest or a TV tech to repair this for you. This info will help you get a reasonable repair bill. Thanks for asking and show a few hands of support.
2answers
I dont want to buy new graphic card how i run resident evil 5 it says unsupported pixel shader 2.0
Try updating your video card drivers. Most manufactures have drivers listed in the support section of their websites. If this does not solve the problem, you will have to upgrade the video card.
I lost the card where my sim was attached when i bought it :( i badly need help ! hope you could help me get my PUK :( thanks a lot ..
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Jan 13, 2011 • Cell Phones
Hi :) i forgot the code i have made for my nokia 6300. i need help badly. :( my imei is: 355234034394334 thank you so much :)
If you have entered the phone (SIM card) password incorrectly 3 times then -
To unlock the SIM card you need the PUK code.
Your cell phone service provider can give you the PUK code once you give then your account details and they have confirmed your identity.
Dec 12, 2010 • Cell Phones
Compaq deskpro 2000 6233mmx OS WInXP Professional, cannot detect pci sound card c-media 8738 pci 4-ch. is the motherboard too old for newer pci devices? Thanks
yes i think it is sorry to the bearer of bad news my freind have you tryed the card in a freinds news computer to rule out the chance itsa a bad card? hope this helps if it does then please give 5 thumbs up
2answers
I locked out my PUK code how do I fix it?
you need a new sim card. PUK codes give you three chances to get it then the sim card is destroyed. If you havent tried to unlock it three times call your service provider they can give you the PUK but if you have already tried three times your sim is fried and number stored on it are gone. Just go in and get a new sim for free.
Feb 22, 2010 • Cell Phones
No sim cards work in Sony ericsson v580i
your SIM is probably damaged, go to your cell phone company and they will tell you if it is bad
please give good ratings,thanks
Insert sim ard after offline sign
Hi
Try checking any other SIM card, if other cards work then your sim card is bad. And, if your sim is not bad then please tell me, we will try and reset your phone to solve this issue.
Please rate this as FixYa if found helpful and ask for any clarifications,
Thanks
Rylee
2answers
When turning the power on get a beep a pause a beep
If your monitor plugs directly into the motherboard, then you need to purchase a video card and install it in your system. The computer will bypass the built in video and use the video card. If your monitor plugs into a separate video card already installed in your system, then that card needs to be replaced. That is what the beep code means when you turn it on -- the computer can't find the video. Oh, and please take a moment to give this solution a fixya rating. Thanks! :c)
Back ground screen flickering
If it flicker continually that may well be either the video card (hopefully not part of the motherboard) or the monitor. Your best bet is to tt on someone else's machine. If it does not flicker then you probably have a bad (or soon to be very bad) video card. If, your video card is built into your machine, don't give up....you can buy a video card and install it....they are not expensive if you are not a big time gamer. Price ranges are anywhere from $8-20 if you are a normal PC user. Pricewatch.com can give you some insight. You will need to know what type of slot you have available....presumably AGP (but PCI, if you have an open slot on the motherboard, will also work....AGP is faster.)
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
