Motorola Mobility 5.8 GHz Digital Cordless Expandable Phone System Logo
Anonymous Posted on Jan 30, 2011
It says "ext. in use"
  • Anonymous Jan 31, 2011
    All bases are plugged in and have been for 4 years
  • Anonymous Feb 03, 2011
    I did all that and ordered a new phone
Ginko
Level 3:
  • Master 19,396 Answers
  • Posted on Feb 01, 2011
Ginko
Master
Level 3:
Answers
19396
Questions
25
Helped
8077766
Points
55462
Hi.
To do the complete troubleshooting, try doing a full system power reset. This is done performing the following, simply disconnecting the power adapter won't be enough:
  • Disconnect all power adapter cables from wall sockets.
  • Remove all handsets from cradles.
  • Remove all battery from cradles.
  • Fit back the batteries in their handsets.
  • Place back handsets in their cradles.
  • Connect power cables.
The procedure above will reset the system and will re-sync handsets to cradles. If that does not work, then some of the units comprised in the system is defective.In that case you will need to replace/repair the faulty handset or the whole system.
From description it sounds like the problem is one of the units. Here a replacement unit.
Before purchasing a replacement I suggest calling Motorola and finding out the cost of a repair or replacement from factory. In U.S. see
Contact Us - Motorola Solutions US
Muzahura Frank
Level 3:
  • Master 2,071 Answers
  • Posted on Jan 31, 2011
Muzahura Frank
Master
Level 3:
Answers
2071
Questions
Helped
445756
Points
5838
Try relocating the base unit for testing purposes, to ensure that the unit is plugged into a working electrical outlet. Verify that the in-use charge light is lit. If the problem doesn't correct itself at another outlet, try the unit on a line outside of your home to test
Toshiba dkt 2010-sd voice mail doesn't answer
To help you I would need to know what type of Toshiba main cabinet you have. If you have a CTX or CIX it may be that your system call forward is turned off. If you dial #620 at the extension in trouble it will turn the system call forward on. #621 turns it off. The proper sequence for "No Answer Call Forward" is Press ext. button + #6031 (tone) + dial main ext for voice mail + timer (08~60)
(tone) . #6051 removes this type of forwarding.
tip
How to change number when sending text messages, iPhone
<p>Sending an SMS from your mobile phone does not need to be complemented with your mobile phone. Google Voice and Spooftel allow you to send a text message from your phone using an application that turns your phone. You need a Google phone Voice to text messages and Spooftel is only available to "jail-broken" iPhones. <br /> <p><br /> <p>Google Voice <br /> <p>1. Visit Google and click on "More" followed by "More" and "Voice". <br /> <p><br /> <p>2. Log into your Google account and click "create an account." Enter your personal data and click "I accept. Create my account." You will receive an e-mail to your alternate account: Click the link in the email to verify your account. <br /> <p><br /> <p>3. Click "Get a Number" and enter your area code and / or word phrase to use as a phone number and click 'Search'. Select the desired number and click Continue. " <br /> <p><br /> <p>4. Enter a PIN code to access your voice mail account. PIN codes must be four digits and can not name the number or range of numbers. Click "Continue" and fill in your phone. <br /> <p><br /> <p>5. Click "Call Me Now." You receive a call to your other number for verification purposes. Enter the code shown on the configuration page of Google Voice and wait for confirmation. After the confirmation number, your account will be set up and ready for use. <br /> <p><br /> <p>6. Open the browser on your mobile phone and go to the address Google Google mobile application downloaded to your mobile phone. Go to your Google account and click "Menu" followed by "Compose" to create and send a text message. The message is sent through your Google Voice number. <br /> <p><br /> <p>SpoofTel <br /> <p>1. Enter a "Prison Break" Cydia on your iPhone and charge the device. This makes it possible to accept non-Apple applications. <br /> <p><br /> <p>2. Open Cydia and hit the "Search" icon. Enter "SpoofTel" in the search box and hit the title when it appears in search results. <br /> <p><br /> <p>3. Click "Install" and "Confirm" to install the application on your mobile. Open the application and click "Compose" option. <br />
on Jul 21, 2011 • Lands Phones
tip
How do i send a voice memo with my blackberry 8830?
The BlackBerry 8830 smart phone, and other BlackBerry phones, come with an application to record voice memos called "Voice Notes Recorder." From this application you can create, store and send voice memos directly from your phone. You do not need to upload the memo on the computer or send it through email (unless the recipient cannot receive multimedia messages).<span><br /></span><br /> <span> <span>Instructions</span> <ol> <li><span>Open "Voice Notes Recorder" on your phone.</span></li> <li><span></span><span>Press the trackball to record the voice memo. Press it again to stop recording.</span></li> <li><span></span><span>Scroll to and select the mail icon while the memo is stopped.</span></li> <li><span></span><span>Select "Send as MMS."</span></li> <li><span></span><span>Choose the contact from the list, or choose "Use Once" and type the phone number of the recipient.</span></li> <li><span></span><span>Add a note to the message if you wish.</span></li> <li><span></span><span>Press the "Menu" button and select "Send" to send the voice memo and message.</span></li></ol></span>
on Mar 12, 2011 • Cell Phones
My voicemail has been set up, but it will not answer calls.. it rings and then rolls back into the main message for the office
Set your Call Forward Busy/No Answer to go to voice mail ext. as follows: Lift the handset, dial 4 then 3 followed by the voice mail ext. (the number you dial to retrieve voicemail messages). Hang up.
When I hit the button on my blue tooth it sends my messages directly to voice mail. How can I fix that.
It almost sounds like you are rejecting a call, and when that happens you will send it to voice mail. It says that if you are tapping twice, it will sens it. I am also giving you the link to the users guide below to try and help.
Plantronics Explorer 230 User's Guide
If this does not work please refer to Plantronics tech service, 800-544-4660 ext 5538.
Good luck from Headsets Direct!
Message light blinking. LCD has myext-voicemail#
I received a voice mail which seemed to correct the problem. Sort of the same solution as when an actual extension is displayed. (you connect/disconnect)
6helpful
Voice mail not working
When someone is calling my direct line, the phone never goes into my voicemail. How do I fix this?
Norstar Flash
phone is not programmed for forward busy no answer.
CAN'T TRANFER CALLERS TO VOICE MAIL
A Panasonic system and Pana branded voice mail has a VM Transfer key that lets you send a caller to voice mail. It's programmed by picking a button down the left side of the keystrip (CO) and pressing PROG, the button, 94+ the VM extension, and STORE. (In a TA-824 system it would be either 107 or 115).
The TRANSFER button would work if the extension has CF set (All Call or Busy/NoAnswer), but there would be a delay. At the very least, when you tried yours, you were either dialing the VM extension which is probably not vailid because it won't let you transfer to yourself, or an invalid extension.
Carl
3answers
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Top Motorola Mobility Lands Phones Experts
Ngoro
john h
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
