You can try this solution for the waste Ink Absorber:
Issue:
ERROR LCD: WASTE INK NEAR FULL
Solution:
Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
- On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
- Wait approximately ten seconds and then press the <ON/OFF> button again.
- Wait until the device has completed its cycling process before submitting another job request.
You can also follow this link to the MP130 page on canon's Web site:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10442
to download a user guides, drivers, views specs, as well as receive
support and service. To search Canon's knowledge base for a solution,
you need to type "waste ink absorber" in the text box on the Support
& Service tab. Click Search then click
ERROR LCD: WASTE INK NEAR FULL. You will be given 4 possible solutions. The one that I provided above is #2.
You can also download the user guide (if this is a windows system, you
will download the user guide from the Software & Service tab. Click
that tab then select your operating system. Scroll down to the table
labeled
Guides and Manuals then scroll down to find the Pixma
MP130 User's Guide and click on the (.exe) file name. The file is
compressed and by running it on your system, the guide will be
decompressed and installed.
Hopefully this solution assists you with the waste ink absorber issue
as well as the other issues that you're experiencing with this printer.
Thanks for using Fixya!
Please share your experience by rating this solution.
