You are actually supposed to be using a special case opener for this type of watch, however, if you want to open it, always remember, righty tighty, lefty loosy!
I am pretty sure those watches are water proof up to 3 ATM, so once you open that watch, just know, if you don't get the back put on tight, it's going to leak.
Good luck, i know you can do it. Oh, and if you have ever had the watch in for service before, there are ALYWAYS **** watchmakers who like to over tighten the watch cases. My husband is a watchmaker, and we have seen this hundreds of times. :)
You will see that they claim 38 hour running when fully wound.
In view of the very small forces involved and the variations that occur in the manufacturing of the mechanism, I don't think that you should be surprised if there is a variation in running time.
If your genuine watch runs for a significantly less time thean they claim, you may have a reason to complain.
Your TAG is fitted with EOL (end of life) feature. This is the cause of
that 4-5 seconds interval movement of seconds hand and thus indicating
the time for battery replacement. The timekeeping is not affected by
this- it is just warning to replace battery a.s.a.p. Find your nearest watchmaker and ask for battery replacement.
This is most likely the "battery change indicated" feature of your watch. Change the battery, and see if the problem goes away. If it does not, then it could be a problem with the stepper motor, which will require a watchmaker. Of course all of this is dependent on the assumption that your watch has a quartz movement. If it is an automatic, or mechanical you have bigger problems.
