Computers & Internet Logo
Posted on Jan 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I HAVE laptop router NETGEar NINTENDO dsi xl Trying to get my dsi on line ???? going round in circles Help anyone?
Nikki Mclean
Level 2:
  • Expert 293 Answers
  • Posted on Jan 30, 2011
Nikki  Mclean
Expert
Level 2:
Answers
293
Questions
Helped
88105
Points
891
Hi nanabarb
PLEASE RATE MY ANSWER IF YOU FIND IT HELPFUL !
At this link you can find all the info you need on how to connect your DSI to wireless internet...
http://www.nintendo.com/consumer/wfc/en_na/ds/connection.jsp#router
On the dsi search the network for your wireless connection and connect to it you will need your wireless network password if you have one for the router...
Error code 051099 keeps coming up.
Error Code: 051099 This error code can occur for two different reasons:
  • You are trying to agree to the User Agreement of the Nintendo DSi or Nintendo DSi XL, but are receiving error code 51099. This can occur if the Nintendo DSi or Nintendo DSi XL tries to connect to Nintendo's servers to download the User Agreement, but there is no existing Internet connection setup on the system. To connect your Nintendo DSi or Nintendo DSi XL to the Internet, please click here.
  • You are trying to play a Nintendo DS game online with a Nintendo DSi or Nintendo DSi XL, but your home Internet is set to WPA security. Please read the following:
There appears to be a compatibility issue with the security settings on your router:
Are you using WPA security?
    No, I am using WEP security
If you are using a Nintendo DSi or Nintendo DSi XL, you will be able to connect online and use many online features with WPA security. However, you will not be able to play original Nintendo DS games that are Wi-Fi compatible, as they are only programmed to work with WEP security. In order to play these games online, you will need to do the following (If you are not receiving this error when attempting to connect games online, click here):
  • Change your wireless security to WEP or temporarily disable wireless security if you wish to connect to the Nintendo Wi-Fi Connection.
  • If you are unable to log into your router or do not know how, you can check our router look-up page (link) to see if it is listed. If your model number is not listed, check any similar models from the same manufacturer for default information. If you are still unable to log into your router, please refer to the router manufacturer or the company that provided it.
  • Make sure your router is not on our list of incompatible routers. If it is, we recommended using a router that is compatible or co nnecting from a hotspot location.
  • The wireless security settings are typically found under sections labeled 'Wireless', 'Basic Wireless' or 'Wireless Security'.
  • Change the security mode to WEP, and chose your encryption type. The 64-bit encryption type typically uses a 10 character key while the 128-bit encryption type uses a 26 character key. Hexadecimal keys consist of letters A-F and 0-9, whereas ASCII keys have no limitations and are case sensitive. Be sure to use the key that is listed in 'key slot 1' and make sure you are not using a 'passphrase'. For specific information about changing your security type please see your router's manual or contact the manufacturer.
  • Important Note: it is recommended that any changes made to the router are performed from a computer that is wired via Ethernet cable to the router. In addition, any changes made to wireless security must also be adjusted on other wireless devices in the home that use the router (e.g. laptops, other game systems, etc). For instructions on how to change these devices, refer to the user manuals for these devices or contact the manufacturer.
  • Establish a connection in connection files 1-3 on the Nintendo DSi or Nintendo DSi XL. Make sure you are putting the WEP key into the Nintendo DSi exactly as it appears on your router page.
If the error persists while using WEP (or if you are receiving this error with other Wi-Fi features), follow these steps:
  • Keep trying, as there may be a temporary network issue. If the problem persists, or has been consistent over a period of time, move on to the next step.
  • Configure the Nintendo DSi or Nintendo DSi XL manually
      Please note: if your router is set to broadcast the network but the Nintendo DSi or Nintendo DSi XL is not finding the access point then a manual setup will not resolve the error. There may be another problem, such as interference, or a basic setting in your router that is causing compatibility issues. Be sure that your router is set to 'Enable SSID broadcast' or 'Enable Wireless broadcast'. If you prefer to keep your network name hidden, verify the correct spelling and case of your router's SSID.
I can not connect to the internet it keeps saying error code:051099 -1
Cannot connect to internet
If after trying the steps above you are still receiving this error code, please call 1-800-255-3700 for further assistance.
Not letting me log on to internet
Error Code: 51099 This error code can occur for two different reasons:
On poke'mon platnium I tried using the gts wi-fi system but it would not work. Why? error code 51099
Error code:051099
Error code : 051099
CANT GET ON INTERNET
Can't get connected to the internet says error code 51099
1helpful
DSI WILL NOT CONNECT TO WIFI ERROR CODE 051099-1
Top Nintendo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Nintendo Computer and Internet Expert? Answer questions, earn points and help others
