My son's Leapster cartridge, Batman: Strength in Numbers, shuts down completely in the middle of the game when you push the A button. Is this just a defective cartridge, or is there someway to remedy it?
Take the cartridge out of the Leapster, blow into the opening with your mouth. Do the same with the Leapster (blow into it). Insert the cartridge and see if that works.
Try this
Ensure that a cartridge is not inserted
Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.When the LEAPSTER menu screen appears, press the A button.Touch each of the crosshairs that appear with the stylus, Restart unit
If you need to sync the device to the stylus just follow the steps below.<br /><br />1. Turn your <span>Leapster</span> 2 off, and remove the game cartridge<br /><br />2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.<br /><br />3. With your finger still firmly on the 'hint' button, turn the <span>Leapster</span> 2 back on. Keep your finger on the 'hint' button.<br /><br />4. The screen should be displaying the calibration screen. You can release the 'hint' button now.<br />5. Press the 'A' button on the right to enter the calibration screen.<br /><br />6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your <span>Leapster</span> 2 throws at you.<br /><br />7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.<br /><br />8. Your stylus and touch screen should now be working, enabling you to sign in as usual.<br /><br />9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on.<br /><br /><b>Thanks for <span>using</span> <span>Fixya</span></b>
You have to make sure that your Cartridges is clean. Try to vacum of blow both of the cartridge hole and also the place where you put the cartridge, Sometime very small tiny dirt will makes that the cartridge cannot be recognise by the console.
Instead of 1 starter game and a few demo game that you get from Leapfrog
Connect, you can also get more downloadable games for your Leapster 2.
You can get it here: leapster-2.blogspot.com
If your Leapster 2 will turn on, but the touch screen is not responding to the stylus, try re-calibrating the stylus with the screen using the steps below:
1. Turn your Leapster 2 off, and remove the game cartridge.
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Are you using it with a game? Will it stay on if NO game cartridge is in & are U able to access & play Pre-installed games?
If so, it may be the cartridge is DIRTY. I discovered this with our Leapster 2. What works for us is getting a Q-TIP & RUBBING ALCOHOL, you want to saturate Q-tip with the rubbing alcohol & clean the CARTRIDGE (NOT the Hand held ).
You want to clean the computer chip @ the bottom by inserting Alcohol soaked Q-tip on each side of contact strip (the part that inserts into the hand held) & with the dry end of Q-tip go over it again, for more cleaning & to wipe up any EXCESS Alcohol. REPEAT this process until Q-TIP comes back CLEAN.
I was really surprised @ ALL the BLACK grime that came off cartridge.
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
