There could be a list of problems... for one make sure you are using a ground cable 4awg or bigger and no more than 18 inches long this must be bolted to the body tight and a clean metal to metal connection. the ground must be the same size or bigger than your power wire. you should have at least a 150 amp altinator and a single dry cell battery. i use drycell to keep corrosion away. the longer your power cable the bigger it should be. at 20 feet you should run a 1/0 gauge power cable at least to a distribution block with the correct size to the amp. if your using a cap all cables must be the same size with the ground same size or bigger.
it's good
that you're asking as some basic sensible first aid advice can make a
difference to how burns heal.
Before you
treat burns you need to figure out the severity; whether they are first, second
or third degree burns. This will depend on the extent of the tissue damage.
First degree
burns are superficial and don't blister. The burn may be red and swollen. Run
the affected area under cool water and you can put some silver sulphadiazine on
it to help the healing.
Second
degree burns may turn white on touch and blisters may develop. The burns extend
to the middle skin layer. To treat; gently clean and dry the area. Apply antibiotic
cream and seek medical treatment immediately.
Third degree burns damage all 3 skin layers and can be very dangerous and even life threatening if they affect over 90% of the body. Treatment involves immediate medical care, fluids will be needed to deal with dehydration and possibly oxygen.
