Call Schwinn customer service (actually Nautilus) at 1-800-nautilus if it is broken so you can order a new one or they will send you a new one if you are under warranty. They are very helpful. You can also check the power connection on the bottom or make sure the wire harness in the main pipe in the center is properly connected if the system is brand new and not working.
Error 1 on a schwinn is a generic electrical error. Check your ac adapter and make sure you're getting the proper voltage off of it. Typically an error 1 warrants a replacement of either the ac adapter, the wire harness (wires that connect the power to the console) or the console itself. If the console has batteries, change those first, then check your adapter. If the problem persists, you're looking at a more in depth problem that will require taking the casing off the machine and individually testing each component of the machine. It's usually worth at that point to pay a tech to look at the machine for you.
