Don't have the codes for that one BUT 09 --- codes always refer to drum/toner problems. Make sure the drum unit is plugged in properly, and cables/plugs etc secure
4112 / D95 families - Fault Code 077-313 : Multi-Feed Sensing Problems. First ... You have the choice to disable the Multi Feed Sensing feature on the machine if you fail to repair the problem or if you have a hard time sourcing the sensor or the board. The NVM Setting code is: 742-268.
Copytechnethttps://www.copytechnet.com > ... > Xerox
Sep 6, 2019 - Cause: Multi Sheet Check Sensor Actuator loose due to torsion spring disconnected from the arm. Due to improper removal of paper jam at Registration Roll.
Xeroxhttps://www.support.xerox.com > en-us > article
Jan 19, 2021 - Power off/on the printer. For details, refer Power Off the Printer Using the Power Switch. Wait Two Minutes and Then Power On the Printer.
Missing: C4430 ' Show results with: C4430
Question edited for clarity.
Please don't type in all CAPS, it is considered SHOUTING which is rude and it makes it harder to read. Lower case additions are mine!
First a fault code on your Xerox printer and or multifunction device is not always as disastrous as you might imagine, no reason to slink away from the machine. The fault code is just a way for your machine to tell you there is a problem and it needs some help. So next write down the complete code and any accompanying error message, the fault code will be numbers and/or letters and may include commas, periods or hyphens. Then find a device on which you can access the internet. At the computer or smart device go to Xerox.com and then select the Support & Drivers tab at the top. Enter the model of your Xerox printer or multifunction device in the field provided and then select the machine and select Support. On the machine support page you will see the "Search For Keyword or Phrase:" field. You can enter the fault code there or right under that field you can click on the "Fault Code Search" link. A new screen will be displayed where you can enter the fault code or you can scroll through all the codes looking for the one you wrote down from your machine
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
9,005.49: Ink loader fault. The cyan ink melt heater is on, but the ink does not
appear to be dripping.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1. Are the ink sticks all Xerox ink? Go to
Step 2.
Advise
customer. Run
clearISCfault
test to clear the
error.
2 1. Manually verify that the ink stick is able to
advance in the ink loader chute.
Go to
Step 3.
Remove any
blockage and/
or replace the
ink stick.Run
clearISCfault
test to clear the
error.
3 1. Run the appropriate Ink Melt [1, 2, 3, 4]
Heater test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
2. Did the test pass?
Replace
the
printhead.
Replace the ink
loader
assembly. Run
clearISCfault
test to clear the error.
06 codes refer to exposure lamp problems..(or scan) check lamp coming on, scan carriage position etc, don't have the code list, so carefully move the scan carriage up and down, make sure it moves OK
