To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Afterwards click the data as well as open it using BlueStacks emulator. facetime iphone leave a comment in below comment box as well.
SOURCE: my calculator won't give me decimal numbers
Use the [S<->D] key to switch between the two.
Hope it helps.
SOURCE: I ask a dividing question like: 8 divided by 10,
If a number is displayed as a fraction or a radical (square root or other roots) you change it into a decimal number by pressing the [S<=>D] key, just above the red [DEL] key.
If you do not care for fractions or radicals, you configure your calculator to display only decimals. To do that you press [SHIFT][MODE][2:LineIO].
Warning: If you do that you will not be able to enter fractions or radicals in the natural (textbook display)
Another way to display a fraction or a radical as a decimal is to press [SHIFT][=] to get the result not the [=] alone.
Hope it helps.
SOURCE: fractions appear when I divide; not decimals
press 'yellow key' then press 'enter' to see answers in decimal format instead of fractions
SOURCE: When dividing the display outputs the answer in fr...
If the result is already calculated and displayed, press the
[S<=>D] key It will convert a fraction or radical to decimal. This
is always possible. If the result is decimal it may be converted to a
fraction or a radical (Not always possible).
If the expression to
be evaluated is still in the command line and you have not pressed the
[=] key, you can force the result to be displayed in decimal format by
pressing [SHIFT][=] instead of just [=].
More permanently. If you
do n o care for fractions and radicals, set the Input/Outpout mode to LineIO.
To do do press [SHIFT][MODE] to access the (SETUP) screen and select
[2:LineIO]
SOURCE: how do i get a decimal on division instead of a
good Apple hardware. You can make use of imo on your imo for pc message messaging, sending out audio, videos, photos, nice.
