Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
    Genius:
  • 1,739 Answers
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Posted on Jan 30, 2011
SOURCE:
Why won't my bunn coffee maker turn on
You should check to insure that the tank inside the machine is full of water. Pour in 1 pot of water at a time until you get water to come out of the brew basket. If you haven't done any internal damage it should be ready to brew a pot of coffee inabout 20 minutes.
Sep 21, 2014 | Bunn 10 Cup Home Coffee Brewer
Cuisinart dgb-650
In an empty machine,(no coffee, no filter), pour in a 50-50 mixture of water and white vinegar. Allow the machine to start brewing and when a cup or so has run through, stop the brewing process and let it sit for an hour or two. This should dissolve some of calcium buildup in the machine and allow it to complete a full cycle. May have to do this a couple of times to fully clean out the mineral buildup. After cleaning, run a pot of clear water through to rinse out the remaining vinegar.
Dec 03, 2017 | Cuisinart Coffee Makers & Espresso...
Coffee Maker only brews 1 cup at a time
Hello. I just talked to Cuisinart and they recomended running a solution of 1 part vinegar and 3 parts water through the brew cycle,then a full pot of plain water to rinse, to remove hard water deposits. The phone # to Cuisinart is 1-800-726-0190. I hope all works out for you.
builderdale
Jan 12, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
My kenmore 12 - cup coffeemaker, model # 80666 is beeping every few minutes. I hit the brew button but nothing happens
In the manual that came with the coffee maker, the beeping is the freshness alert. When coffee is finished brewing it beeps 5 times. Every 15 minutes it beeps to let you know your coffee is 15 minutes less fresh! I just purchased this coffee maker and was looking on here how to dis-assemble the beeper. Whomever came up with the "freshness beeper" on a coffee pot needs a new job! Usually when I make coffee the whole house is asleep, now the beeping is waking everyone up! Very frustrated with this coffee pot!
Nov 02, 2009 | Kenmore Coffee Makers & Espresso Machines
Brewing time is too long 20 min for 6cups
You have an obstruction in the feed line to the heating element. I found coffee grounds before the check valve. I had to take the bottom off it which I am sure the manufacture wouldn't approve of but I was at my wits end and ready to toss it. I just brewed a full pot 10 minutes!!!
Aug 18, 2009 | Cuisinart DCC-1200 Coffee Maker
Won't make full pot
Okay, try this, make sure that everything is cool first, then take a turkey baster full of hot water and vinegar and shoot it backwards through the coffee maker...where the water falls on to the grinds. After that, try running either a commercial coffee pot cleaner or just again, vinegar through the brew cycle with no coffee in there. Try it two or three times, there may be calcium buildup in the filter and pump. You could also try that CLR cleaner, but make sure you rinse the pot out really good, and run a few cycles of just water before you drink anything from it.
Hope this makes sense and helps you out!
Jan 12, 2009 | GE Coffee Makers & Espresso Machines
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
10 cup cuisnart stainless steel & black coffee maker
The beep indicates numerous things. If the top lid is open, it will beep, if you try to depress the brew or timer buttons.There is a button next to the grinder unit, that gets depressed when you close the lid. Check the lid to make sure the tab on the lid hasn't broken. The beep also indicates that brew cycle has finished, although, that is supposed to be only 5 beeps.
Feb 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
853 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
