If the cold water only comes out at a trickle, you need to replace the valve. I have had to replace the hot and cold water valves on my washer every couple years.
it could be that the water level got to high and came out of the valve you could try putting a cap on the valve and see if that works and if it does not then it might be a bigger issue.
Hi just read your posting.Have you selected cold only?Are the hoses from the taps going to the correct water valve?Cold tap to c on the machine and hot tap to h on the machine.What is the model number of the machine?The model number sticker is on the back of the machine up top.Please reply with additional information and I am sure I can help rectify the fault.Looking forward to your reply/
THE VALVE IS BAD OR THE SCREEN TO THE VALVE IS CLOGGED. TO CHECK TURN OFF COLD WATER. REMOVE HOSE FROM VALVE. LOOK INSIDE VALVE. THIS SCREEN YOU CAN PULL OUT AND CLEAN IN A SINK.
unfortunately it sounds like you have a stuck plunger in the cold side of your water inlet valve.if the screens are clear and your water pressure is good,thats what you have.
