The best solution would be to see if your TV has and aux out for sound. It might also be called audio out. I would look like a red and white jack next to each other by themselves. Then you would take and audio cable and connect the audio out from your TV to the AUX in on the back of your Sony unit. Then select the AUX input selection on your Sony unit to hear the sound.
If you don't have an audio out on your TV then you can plug the red and white cables that go from your Wii console into the AUX input on your Sony unit. The only down side to this is you will ONLY have surround sound and no sound on your TV. Also you will have to pull your Wii cord apart a little bit to reach wherever you will need to plug them.
Please thank me if this helped.
