HP Deskjet 3845 InkJet Printer Logo
Posted on Jul 19, 2008
Problem printing business cards
When I load a regular sheet of paper the business cards print 1/2' from the top, where they should but when I load the business card perferated paper the text starts printing at the very top of the page. That throws off all the cards, not to mention wastes ink and paper.
Before this problem I was able to print 50 business cards. I have a total of 4 different kind of cards to print. The first one came out fine but I can't seem to print the other 3 correctly. All my settings are correct: 3.5x2 cards, 8.5x11 paper, 1/2" margin top, bottom,and sides. What am I doing wrong? Please help. Thanks
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
514
Points
I had this problem today and think I've figured it out. Take a sheet of plain paper and two little pieces ot clear 'scotch' tape. Tape the blank sheet behind the business cards at the top/feeder edge and try again. You may need to tweak it a bit more but it stops it from printing so far up.
Kelly Nevers
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 3 Answers
  • Posted on Aug 16, 2014
Kelly Nevers
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
549
Points
6
Reset the printer. It will work sometimes it happens. All the best.
Paper won't feed
Inside of the machine is dirty.
If the inside of the machine is dirty, the printed paper may be smudged.
Follow the steps described below to clean the inside of the machine.
1. Ensure that the machine is turned on and there is no paper loaded in the Auto Sheet Feeder.
2. Place A4/Letter-sized plain paper in landscape orientation, horizontally fold it in half.
3. Unfold the paper, and load the paper in the Auto Sheet Feeder with the inverted-V edge down.
4. Select <Bottom plate cleaning> from <Maintenance>.
5. Select <Yes> on the Bottom plate cleaning confirmation screen and then press [OK].
Paper will be ejected.
If protrusions inside the machine are stained, wipe ink off the protrusions using a swab or such like.
* Important
Before cleaning, be sure to turn OFF the machine.
Paper feed roller is dirty.
Follow the steps described below to clean the paper feed rollers.
1. Ensure that the machine is turned ON and there is no paper loaded in the machine.
2. Select <Roller cleaning> from <Maintenance>.
3. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper feed roller will rotate as it cleans.
4. Repeat this operation twice.
5. Load three or more sheets of A4/Letter-sized plain paper lengthways in the Auto Sheet Feeder.
6. Select <Roller cleaning> from <Maintenance>.
7. Select <Yes> on the Roller cleaning confirmation screen and then press [OK].
The paper that is loaded in the machine will feed through the machine and be ejected.
8. Repeat Steps 5 to 7 three times.
Inappropriate paper type is used.
Check to see if the paper you are printing on is too thick. See Paper Types You Cannot Use.
Note that smudging may occur at the top and bottom edges of the paper when using Borderless Printing. Ensure that the paper you are using is compatible with Borderless Printing.
Thick paper is used.
When printing on thick paper, set the Paper Thickness Lever to the right.
This widens the gap between the FINE Cartridge and the paper. Try this maneuver if the printed surface is scratched.
Media is curled.
If all four corners or the printing surface of the paper is curled, the paper may become dirty or may not feed properly. Use the paper after correcting paper curl as follows.
1. Place the printing surface face up (A), and cover it with a sheet of non-printing regular paper to avoid damaging the surface.
2. Roll up the paper in the direction opposite to the paper curl as per the figure below.
3. Check the printing paper to confirm if the paper curl is eliminated to within approximately 2 to 5mm / 0.08 to 0.2 in (B).
It is recommended to print on curl-corrected paper one sheet at a time.
The media type is not selected correctly in the printer driver.
On the [Main] tab of the printer driver, ensure that the [Media Type] selected matches the paper loaded.
In the [Print] dialog box of the printer driver, select [Quality & Media] from the pop-up menu, and then ensure that the [Media Type] selected matches the paper loaded.
Paper is loaded incorrectly.
Load in the portrait orientation regardless of the print direction of the Auto Sheet Feeder.
Ensure that paper is loaded correctly. Slide the paper guides against the paper stack.
2answers
Paper goes through tray 1 the image prints landscape on portait
Try placing the business card sheet in the main paper bin instead of the manual feed or adjusting the print orientation from Portrait to Landscape or vice versa.
1helpful
When I print a ten sheet business cards.The text is moved down on every card.1 cms form top first card, last card 6cms
it maybe from the settings, do you still have the same issue on printing regular documents. it may also differ with your program
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Paper is feeding unevenly on black & white prints
    If the paper is lodged too far into the printer and can't be removed:
    1. Press the power button to turn the printer off.
    2. Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
    3. Close the front cover.
    4. Press the power button to turn the printer back on.
    5. Resend your document to print.
    Ensure that:
    • The paper is a recommended paper for inkjet printers.
    • You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
    • The printer is on a flat, level surface.
    • The left paper guide is against the side of the paper.
    • You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
    • The left paper guide does not cause the paper to bend in the sheet feeder.
    • Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
    • Envelopes or the appropriate specialty papers are selected in the printer driver.
    • You are using a paper or envelope size supported by your printer.
    Important: Your application may not be designed to print envelopes. For help, consult the documentation that accompanied your application.
    1helpful
    Printing business cards
    Feed sheets through front manuel feed slot.
    base tray is mainly for up to 90grm paper,anything heavier
    can feed for a time but tends to fault.also try and clean the
    paper pick up rollers regularly.
    mongrelken.
    in your program adjust the pic your printing to fit in yours sumtimes u have to adjust your print in preview box your card u made down or up whole thing so it fits in nice for u sumtimes they just dont line up right i had same issue just move your project up with it ok to make it print in box cards u need ok
    Only prints business cards correctly on plain paper, but not on the card stock.
    I am the guy with the hp d'jet D2445. I ran out of card stock in failed attempts. Not wanting to give up I bought more (Avery, no serrations) and it worked fine. Don't ask why.
    Print Garbage
    The reason your pictures come out dark and grey is that you have not set the paper thickness on your printer. On the back you will see a flip switch change this setting then feed your business card sheet in there and see the diffrence. Plus make sure your settings for your printer are set for a thicker paper this will fix your problem. Make sure though when done printing your cards that you set it back to the normal or you will have problems printing regular paper documents.
    HP 1310 series
    I have an HP PSC1315 which is virtually the same printer. I actually created my own template where 10 business cards are printed as if it were one sheet of paper(like a poster). Of course you you can't select how many cards print, or which card to start on, but at least I get 10 perfectly centered cards.
    k24674
    Grand Canyon Tech
    Grand Canyon Tech
