American Standard 2004.014 - Champion Elongated One-Piece Toilet Logo
Posted on Jan 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I just need the tank for a Champion 4 elongated toilet.
Anonymous
Level 3:
  • Master 528 Answers
  • Posted on Jan 30, 2011
Anonymous
Master
Level 3:
Answers
528
Questions
0
Helped
274305
Points
1396
If it's not a one peace tolet you should find what your looking for here.
http://www.thefind.com/hardware/browse-american-standard-champion-tank
American Standard Carlyle Series toilet is refilling about 10 percent of the water in the tank every 20 minutes. Do I need to replace the flapper or the entire flush valve?
Start with the flapper. They tend to dry up especially with water that contains chlorine. Purchase the American Standard flapper if available for that toilet. Works better than generics.
I had an American Standard Cadet3 Right Height Elongated toilet installed. After flushing, water level in the bowl drops to a very low level. Enough remains to prevent gasses or orders, but just enough. I...
Adjust the water setting of the tank to higher level, meaning an additional water will be added to the tank. The purpose of this is to release extra water that will fill the missing water level in the bowl.
1helpful
Problem: water tank running water and refilling itself
probably the flapper valve is not seating correctly over the outlet. you can fix it by reaching in and twisting the valve one way or the other till it seats properly and the leak will stop.
My champion 4 two piece comfort height elon toilet keeps running. I have to turn the shut off valve off to stop it. Help! John
take off the tank cover and you'll see "the flapper" not sealed against the hole where the water goes to the bowl, the chain that holds the flapper might be tangled or flapper is real bad,.....you'll see what the problem is,..
Not flushing
take the lid off the tank and make sure that the chain is still conected from the flusher handle at the top of the tank to the plug at the bottom of the tank
1helpful
Home Depot Pegasus Elongated Toilet I need gasket between tank an
Strange that it went, but do you still have it? If so, bring it to your plumbing supply store and they should be able to match it up. Not sure why Home Depot can't help though. If you do not have it, bring the tank so they can try it right there. Good luck and make sure you don't overtighten when reassembling (can crack easier than you think). Can always tighten, but never loosen when it's too late.
1helpful
Water leaks from tank to bowl till water level in the tank is jus
Yes. You will have to remove your tank from the bowl to replace the defective fill stack(the tube thing your flapper is attached to) it is not as hard as it seems.First remove water supply tube.Then remove the through the tank bolts. should be two of them. Lift off and turn tank upside down. remove spud gasket. Unscrew old stack. You should be able to get a universal kit to work with your tank and should come with all new parts including new flapper and spud gasket. You will need new through the tank bolts and note the sequence of assembly to get water tight seal on tank. Hope this helps
Toilet keeps flushing
you need to replace the flapper, it's allowing water to seep thru
What is square box (float) attached to flush valve inside tank
The foam block does a few things: It helps with noise level, helps prevent condensation and also takes up space in the tank to lessen water usage with each flush.
Keep an eye on the outside of the tank and if you don't ever notice any moisture on the outside of the tank then I wouldn't worry about it all!!
1helpful
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
