Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
Posted on Jan 29, 2011
I cant find rings for a tecumseh hm80-155356n
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
899
Points
40049 is the Tecumseh Part # for a Standard Ring Set, let me know if you need part #'s for OS Rings
Tecumseh manuals free
mmm interesting.after comming up to temperature engine experiences excess blow by into crank case .doutfull if it has the wrong size rings for the cylinder as there would be other syptoms as well.think some thing is going on with the reed vave sticking open causing pressure build up into crank case
Jun 29, 2014 • Garden
Tecumseh hmsk80 oil coming out breather
Broken rings is what it may be
V twin tecumseh
If it not getting gas or is not fireing the fuel pump must be working or the other cylinder would not be getting gas sounds like rings bad or head gasket but make sure it is getting fire first
1helpful
10 hp tecumseh throwing oil out the breather tube
There is excessive blow- by from the combustion process which indicates worn rings /broken rings or scored bore (engine worn out or dusted). Check oil level in sump as excessive oil will also cause the problem
Tecumseh ohh55 smoking/burning oil
http://www.repairclinic.com/Tecumseh-Small-Engine-Model-OHH5569024F-ID-806444-Parts
one of many suppliers on the web- lol
Ring gear on flywheel
Hello
The most part of the Tecumseh engines are prepared from factory to install electric start .
Just remove the cover on the side of the motor and if you have the ring gear allready installed on the flywheel you just simply have to install the electric start . Make sure the gears on the electric start will match the ring gear .
Hope this help
1helpful
Warranty info on 8 hp Tecumseh motor
rowville mowers 03 7534443 can help you with a warranty issue.. BYNORM is the company that handles the Tecumseh engines... you could ring them for you nearest local dealer (03 9796 4244 bynorm no.)
2006 toro,,tecumseh 6.5...prime,pull cord, starts, then quits...just rebuilt carb, main jet,red plastic, two o-rings,,new bowl cover o ring, repace gasket on main bowl jet, i cleaned it all, blew out all...
Morning,, yes I did find the problem.. previous person that worked on it installed the main jet tube upside down. The Red one with the two "O" rings on it. I cut off the crimped end and opened the hole and reinstalled it and it started right up.... Thanks anyways....
Tecumseh HM100 piston replacement
standard size rings & im sure it the torque should be 40 in pounds
Jun 08, 2009 • Garden
3helpful
Oil blows out of tube
You either have a head gasket going bad or your piston rings are shot which causes air to go down into the crankcase building up pressure which exits through the breather tube.
Top Tecumseh Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
