Question about Akai MPK mini MIDI Controller Keyboard, 25-Key
I brought a akai mpk mini and when i plug it into my laptop, the sony vaio ns-series VGN-NS30E says i need driver software to use it. the keyboard works on my computer though (dell volstrom 220 mini tower), so i want to know why isnt it working on my laptop and would do i need/to change in order to get this keyboard to work?
  • Akai Master
  • 5,603 Answers
Your machines are different and likely have different interface chipsets. Some newer machines have more built in plug-n-play than others. There is so much incompatibility that it is a wonder that any of the stuff works together. You need to install the needed driver... NOTE: there is a lot of incompatibility between OS versions... so if for instance you are using XP on one machine and Vista or Windows 7 on the other there are a LOT of incompatibilities. ALWAYS check the requirements for the computer with the specs of the device to be connected. MOST of the problems are due to OS variations. Check for driver updates on the Sony site
Posted on Jan 29, 2011
SOURCE:
Can I get my akai keyboard port repaired as its damaged?
I see no reason why not...but that will depend what part of the country you are in...where are you located???
Jan 20, 2014 | Akai MPK mini MIDI Controller Keyboard,...
Akai mpk broken conector
Its a lot simplifier than that really.. all you need to do is unsolder the old one and re-solder the new one.. The pins and connectors are standard.
Dec 30, 2012 | Akai MPK mini MIDI Controller Keyboard,...
No sound
no sound well it has to be used w something from garageband reason, etc u cant just plug it in and play it . so for instance garage band , you wanted the grand piano u open the grand piano and start hitting the keys. should be no problem I have the same one
May 14, 2011 | Akai MPK mini MIDI Controller Keyboard,...
Akai MPK mini MIDI Controller Keyboard, 25-Key ... my keysare broken from were it clips on
I have the same keyboard, what do you mean from where it clips on. Do you mean the keys itself are broken? I'm not sure how you did that, but you can contact Akai and see if they will send you a new one. Those keys are supposed to be pressure sensitive and unbreakable. Please rate me for assisting you today! :-) PS I love that little thing!
May 09, 2011 | Akai MPK mini MIDI Controller Keyboard,...
Is the MPKmini compatible with sony music studio8
It should work as a generic midi controller if it isn't listed
Mar 11, 2011 | Akai MPK mini MIDI Controller Keyboard,...
My knobs of my AMAY MPK mini just don't work!
This is likely a software you are using with this is either not compatible with those particular controllers OR is not set up to use those controllers. Someplace those need to be mapped into whatever you are trying to control with the knobs.
Mar 07, 2011 | Akai MPK mini MIDI Controller Keyboard,...
I need sound please
Make sure to plug it in before you start up the application. Make sure you restarted your computer after installing device.
Did you check system preferences to see the output settings?
I have mine set to output as headphones and have some external speakers in them. If I unplug them the computers speakers turn right on automatically.
Mar 03, 2011 | Akai MPK mini MIDI Controller Keyboard,...
Open Questions:
Akai MPK mini MIDI Controller Keyboard, 25-Key Logo
1,003 people viewed this question
Top Akai Music Experts
Michial Gueffroy
Cameron Lewis
Cameron Lewis
Level 1 Expert
Bernie Scott
Level 1 Expert
Are you an Akai Music Expert? Answer questions, earn points and help others
