King Kutter ATV SeederSpreader  350Lb Capacity Model ATV () Logo
Posted on Jan 29, 2011
Is the King Kutter ATV SeederSpreader suitable for applying lime? If so what setting shoud be used? Thanks, Doug (Giles County, VA)
Anonymous
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Feb 09, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
0
Helped
15146
Points
21
Lime should be applied at 50 lbs per 100 sq ft which is heavy mark off 100sq and see what it takes at 3mph
How often and quick do the questions get answered here? what kinds of questions are ok for asking here? and does everyone seem to find the helpful? I am trying to find answers for the bossman here at a...
Ask a more specific question about what you want help with. The site is self explanatory. Statistics are irrelevant. Obviously, if you don't ask a specific or pertinent question, the wait time is forever.
I have a King Kutter brush hogger and am having trouble getting it connect to the New Holland tractor. The man who connected it for me last year is no longer around and the man I hired could not get it...
You are talking about a three point hitch ... they can be tricky. Might be worth the time to go to the farm supply store in your community and take a look at how it should be hooked up and operated. It is dangerous to operate this device with out some training.
Not turning the soil
I have run into a couple of issues with these. First is the traveling wheels sometimes don't lift high enough or fall The second is that the unit sometimes works better with cement ballast added to the top of the unit. This may not be your issue at all, but I hope it helps. Please let me know if I can be of further assistance:)
4' king kutter makes grinding noise at times
USE SAY A BROOM STICK AND ON THE OUTSIDE ON THE DECK YOU CAN USE IT LIKE A STETHOSCOPE AND PUT IT TO YOUR EAR AND LISTEN TO DIFFERENT SPOTS ON THE DECK TO HELP YOU ZERO IN ON THE CULPRIT .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
2helpful
How much gear oil 72'' tiller
In Gearboxes use gear oil (type GL5-85W 140 or Triple Zero
Grease; which can be poured, and has "EP" i.e. "Extreme Pressure" additives.) Fill the gearbox to approximately half-full level.
6helpful
2answers
My king kutter till will not hold gear oil.
If it is leaking around the shaft you can replace the seal.
Top King Kutter Garden Experts
Jay Finke
Jay Finke
john h
CJ Rock
CJ Rock
Are you a King Kutter Garden Expert? Answer questions, earn points and help others
