SOURCE: Hooking up a PS3 through HDMI
what you have to to is hold the start button till the TV shows 480i then you will have what you need, it will set up for your tv
SOURCE: PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
SOURCE: When I hook my ps3
Turn the system off, then push the power button for 5-10
seconds. That resets the video to the minimum setting.
Or
*WITH NO DISC INSERTED* If there is one, eject it and turn the system
off so I can show you from a system start with no disc. This IS using a HDMI cable as well
1)Power on system; do NOT push any buttons on the controller!
2) Over 4 to the left
3)9 down
4) Click 'X' once
5)Click 'X' again
6)Click 'X' again
7)Click 'X' again
That should bring you to some settings list that makes sure that the settings you clicked were what you want.
Good luck.
SOURCE: ps3 hdmi is saying format not supported on my 32"
hi
there maybe some problem with ur tvs resolution. ps3 outputs full hd high resolution video(1080p) through its hdmi. may be your tv is not supporting that resolution. connect ps3's component video out to ur tv and then try. if it ask for any resolution selection. select 720p or 1080i, above that resolution ur tv will not support. ur tv is hd ready one, not full hd. ps3 's hdmi out is full hd (1080p).
or try this
connect ur ps3 to any full hd tv and then goto video setup of ur ps3. change resolution to 1080i (down scaling ). then connect to ur tv via hdmi. surly u will get the video.
ok
SOURCE: when i plug in the
You'll have to change the resolution on your PS3 to match your TV resolution by going to settings>video settings.
