posted by bobbiflower on Jul 17, 2008
Report abuse
I own a frigidaire smoothtop range model # PLEFM399DCB.I was cooking hot and spicey beef jerky in the oven, temperature 320 degrees.The steam from cooking was coming out of the oven vent which caused water to sit on the smoothtop and then the beeping started and F7 and 20 and 22 kept flashing on the controls.Could the water have got in the control panel.The beeping just keeps coming on.
Still need a solution for this problem?
Same as bobbiflower's! Did it go away? I tried to reset it by turning the breaker off, but it won't stop! HELP!!!!Same as bobbiflower's! Did it go away? I tried to reset it by turning the breaker off, but it won't stop! HELP!!!!
I will have my husband call the number and see what they say.We have the manual and did what it said but it will not stop beeping.Thank you for taking the time to help me. BobbiflowerI will have my husband call the number and see what they say.We have the manual and did what it said but it will not stop beeping.Thank you for taking the time to help me. Bobbiflower
Go online to www.Frigidaire .com and you can enter your model # and download the manual. if you can not locate the answer in the book,
I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Hey Scott, thank you for your inquiry!
Based off the information you have provided your Frigidaire range is displaying an error code of "F7" and it is beeping. Typically, "F7" stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F7" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
www.shopyourway.com > Manage My Life > Questions Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
http://www.consumerreports.org/cro/kitchen-ranges.htm
Freestanding electric smoothtop ranges are the big sellers, but you have more choices than ever. Our Ratings include smoothtop ranges, of course, but you'll also find induction and coil-top ranges in the electric category, along with gas, dual-fuel (gas cooktop, electric oven) and pro-style ranges. Choose a single oven or double-oven range, freestanding or slide-in. We test all of these. Consumer Reports offers you buying advice that you can trust. We provide unbiased Ratings and range reviews to help you choose the best range for your needs and budget, and use our buying guide to learn more about range types and features that matter most.
Ratings & recommended kitchen ranges
Electric smoothtop ranges (62)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More Recommended electric smoothtop ranges Electric smoothtop range Ratings
Electric induction ranges (9)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More Recommended electric induction ranges Electric induction range Ratings
Electric coil ranges (10)
Our Recommended ranges can do it all and, based on our survey of thousands of readers, do not have brand reliability issues. The Recommended ranges will bring pasta water to a fast boil, hold a big batch of spaghetti sauce or chili at a low simmer, a... More Recommended electric coil ranges Electric coil range Ratings
Gas ranges (43)
Do you love cooking with gas? Our Recommended gas and dual-fuel ranges (which pair a gas cooktop and electric oven) are top scoring and, based on our survey of thousands of readers, do not have brand reliability issues. They have large cooktop burner... More Recommended gas ranges Gas range Ratings
Pro-style ranges (34)
Pro-style ranges are stylish, stunning, and make a statement. But despite their high price, they aren't the best ranges we've tested. So before you swipe your credit card check our Ratings. You'll see the top brands, including Viking, Wolf, Thermador... More Recommended pro-style ranges Pro-style range Ratings
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
in version 1 of your model, F7 requires the replacement of the EDC (electronic door control) in later versions F7 requires the replacement of the EOC (electronic oven control)
1-800-905-9505
They answer 24/7
Thank you Neil
NO PROBLEM DID NOT GO AWAY BEEN THREE MONTHS
