Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
Posted on Feb 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire FRSHB5EHPW1, a few days ago water leaked from the water filter at the top of the refrigerator side. Now the temperature level light is flashing at 4. I moved it up to 7 and it defaulted back to 4. I tried turning the refrigerator off and then back on but it didn't help. Any ideas?
geob91
Level 2:
Passionate:
Visited the website for 10 consecutive days.
  • Expert 128 Answers
  • Posted on Feb 10, 2018
geob91
Expert
Level 2:
Passionate:
Answers
128
Questions
0
Helped
83355
Points
414
The Flashing #4 occurs when power is applied to the fridge and the control board goes through it's cycles and didn't detect a damper connection.
So its your air damper thats bad.
part# is 241600906
Frigidaire FRSHB5EHPW1, a few days - r0705160-00005-n1dvgax2is1j2ueeyj0buc1k-1-0.png
4 Related Answers
A
Anonymous
  • Posted on Jul 07, 2008
SOURCE: 2003 Frigidaire FRS26BH6CBO Side By Side Problem
DEFROST PROBABLY SET TO AUTOMATIC..NEEDS TO BE REPLACED THEN ALL WILL BE WELL
Anonymous
  • 379 Answers
  • Posted on Dec 30, 2008
SOURCE: still walting for the owner's manual that was promised.
you will see the OWNER GUIDE ENGLISH .download
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FRSHB5EHPW1&User=&Search=Search
thanks for the detailed product info , it helps alot .
Anonymous
  • 111 Answers
  • Posted on Jun 19, 2009
SOURCE: Frigidaire refrigerator side-by-side freezer making loud noise
fan motor probably rubbing in something
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Jul 03, 2009
SOURCE: my refridgerator is leaking water from the front
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
The fridge should be 40 degrees on lower but not 32 degrees of course.
NO ICE CUBE PRODUCTION
Check the water filter - may need to be replaced. Check your water connections for loose areas or water leaking. Might not be getting enough water. Check freezer temperature. If the temperature rises it will not produce ice at all.
1helpful
Ice maker not making ice
Try changing the filter; our refrigerator did the same thing.
1helpful
Water dipsenser not dispensing any water
ONLY TWO POSSIBILITIES I CAN THINK OF IF ITS NEW COULD BE FREEZING IN THE DOOR LINER
IF NOT PROBOBLY NEEDS A NEW VALVE
3answers
2answers
Water dispenser and ice-maker do not work
open ice maker cover buy pass T_H will move if still water not come in ice maker change fill valve
2answers
Slow water flow
dadcanfix. There are two possibilities here. One could be the water valve itself, clogged or not seating or opening properly. The second would be the water tank on the refrigerator side, partially frozen. I believe they have a kit now with coiled tubing that replaces that tank because of the trouble they had with it. Remove the refer drawers and take a hair dryer and go over the tank lightly. See if that improves the water flow. Catriver..post back.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
