Yes there is.. BUT you'll have to set up the security again... Fortunately DLink has a handy setup wizard which you can access here.. http://support.dlink.com/emulators/di514_revc/h_wizard.html
This will work right on your browser. You might want to test that it works on your system before wiping the router. (Just start it up then cancel if it starts)
Find the recessed reset button on back of the router close to the power input. Press and hold it with paper clip or pen tip for 10 - 15 seconds. This will restore it to factory settings.
You should use a wired connection to access the internet after that, no password. Go to the link above and use the online wizard to setup the router with encrytion and new password.
If it all orks wout for you kindly give me a rating. Thanks.
How do I reset my router back to the factory default settings?
A few months ago someone was getting into my - a_detail.jpg/uploads/images/a_detail.jpg" alt="a_detail.jpg" class="h_mi" />
To perform a reset, please follow steps below:
Step 1 With the unit on, place a paper clip into the hole on theA few months ago someone was getting into my - reset.gifthe unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
If you have the European version of this router, this procedure may not work. Please consult the D-Link offA few months ago someone was getting into my - q_detail.jpg. D-Link USA does not support the European version.
A few months ago someone was getting into my - a_detail.jpguploads/images/q_detail.jpg" alt="q_detail.jpg" class="h_mi" />
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
If you have the European version of this router, this procedure may not work. Please consult the D-Link office near you. D-Link USA does not support the European version.
If you remeber the IP address and password to access your router you can log into it with your web browser by entering the router IP into your web browser and going to the wireless tab.
The tab defualt IP is 192.168.0.1 the default username is admin and yo leave the password feild blank.
Once you click on the wireless tab the wireless key will be listed.
If you dont have the IP or username/password for the router you can reset the router to the factory defaults then set it back up.
Ffor the user manual for this router and FAQ go to the manufactures website for this router http://www.dlink.com/products/?tab=3&pid=DI-514&rev=DI-514
I hope this was helpful,
Shawn
Resetting the router does not reset the firmware to an earlierA few months ago someone was getting into my - q_detail.jpg will change all settings back to factory defaults.
Note: The A few months ago someone was getting into my - a_detail.jpgults username is admin, and there is no password.
Thanks,. Fortunately I was able to change WEP password and now I can access the internet on my ipod by joining my network with my new password, which I wrote down this time. Thanks again
