Don't IR illuminator in the dark room. Turn on a small light in one of the corner; such as, a small light bulb. increase ambient light a little at a time until you can focus. You flooding the dark room with IR illumination which will reflect everywhere in there. This might take care of the fuzziness in the monocular. stewbison
If a lens has an "A - M" switch, move it to "M" to manually focus. If the switch
says "M/A
- M " then leave on M/A (unless you're going to be taking several or more in manual mode), as these lenses may be focused manually at any time in either position. As soon as you tap
the shutter button in M/A you return to autofocus.
More advanced lenses, like the 18-200mm, 70-300mm VR and 18-135mm,
and any lens with an M/A position, may be focused manually at any time
without moving any switches. Leave them in their A or A/M positions.
I hope this helps and good luck!
