Most newer vehicle have the rubber ring type gaskets now.I know this is not a newer vehicle but say late 90`s and up.If it came in the box with the thermostat then it is more than likely the right one.I know some people will still use a paper gasket along with the rubber ring one.But it should not leak.When you remove the thermostat you should be able to see what your vehicle comes with.Hope this helps.Good luck.
