I reckon yer phone is stuffed as there is a loose connection in the headset jack and thus the phone thinks there is a plug in there all the time. The only suggestion l can make is to get nail 3.5mm the size of the plug and stick it down the hole an give it a wiggle (at yer own risk of course ) this should shake up the connections an should be all good again.
SOURCE: Sync the headset
You never said what model is your phone but the general practise is to pair the headset to the phone.how?? Make sure the headset is fully charged ,normally showing blue light depending on the brand. 1>While the phone is on ,press a button on the headset and it(headset)should show a blue light depending on the brand. 2>keep this button pressed and go to your phone's bluetooth configs and select a 'add audio divice' tab.The phone will search for for any headset in the vicinity till it finds yours. 3>Select your headset name shown on the phone and you could be required to enter password to pair,in this case most will be (0000)or (1234). Sorry had to be this long!!!!
SOURCE: I can set up my headset to my new phone
These are from verizon wireless.com. Support Phones & device Choose phone Choose device Help topics How to pair handset to headset
SOURCE: headset will not pair up eith razr phone.
i had this headset with my old motorola and wanted to pair it with my new razr, but no technical info, couldn't find my book. this worked perfectly, just remember the verizon default pin is 0000
SOURCE: how to reconfigure the H500 headset with a new phone?
Turn off your earpiece.Then turn it back on but hold the button until the blue light comes on and stays on.(that puts it in discovery mode) Now go to bluetooth devices in you r phone and search for the device.
SOURCE: my jabra headset won't pair with my phone--my
Assuming you're talking about the Jabra BT2050 headset press and hold the center (round) button for at least 10 seconds; light will stay solid entering the pairing mode. Follow instructions on your phone.
Testimonial: "This worked perfectly! Thanks!"
