Hello Lester, These Kodaks use codes for diagnostic reasons, they will show a code when there is a reason for service. They are used by the tech for diagnostics just like your vehicles fault codes. Best Regards, Russell
You probably have a firewall on your PC (or mac), or router preventing you from connecting to the internet, either plug the cable to the router, disable the firewall (if using a Netgear router, disable the "SPI firewall" under the "WAN setup" of your router), your Internet Service Provider or ISP might be preventing systems like the wii to connect, check with the ISP to see if they are or not.
F 10 error code is not listed on my error code sheet and in my experiance error codes not listed are internal controlboard error codes and the control board should be replaced.
If automatic configuration is not working (it expects DHCP to anser; i.e. to get an assigned IP address) try manual configuration. Enter the values as you would on your PC to connect to the network.
