Hi,you can unlock your mobile by unlock codes..the safe and best way of unlocking is by unlock codes and my personal request is that don't go for software unlocking because sometimes the software might get corrupted and may your data will be lost due to that,its my bad experience so I went for unlocking by codes from here UnlockGenie.com and unlocked.you can too try but see to that whether your country and provider is listed..because for some service only codes are available..check with that and if your country's provider is listed then get codes and unlock your blackberry..before unlocking your mobile you can get clear instructions about how to unlock your mobile for that you can visit UnlockGenie.com to get step by step instructions..
You can contact the service provider..........
Super Unlock Codes
var x = document.getElementById("business_name").innerHTML;
var i = 1;
while (x.indexOf(" ") != -1)
i++;
x=x.replace(/ /i, "-");
var z = i / 2;
var y = parseInt(z + "");
var xy=x.split(" ");
//alert(xy.length);
var wstring, gstring;
wstring = "";
gstring = "";
for(z=0;z" + wstring + "" + gstring;
Warning : Do not enter any wrong unlock codes on your LG C2000 mobile phones. If you enter over a certain amount of wrong unlock codes on your LG C2000 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your LG C2000 with a NOT ACCEPTED* SIM Card.
2 - LG C2000 will display "phone restricted" Select "Cancel".
3 - LG C2000 will display "phone restriction code" Enter the Unlock code. Select "OK".
4 - The handset is now successfully unlocked.
*NOT ACCEPTED : We mean, to use a sim card from a network other than the network your LG C2000 is locked to.
Each LG C2000 mobile phone has an unique unlock code. You can buy the unique unlock code for your LG C2000 mobile phone using the form above.
Supported Services
You can use the following Super Unlock Codes unlocking services to get the unlock code for your LG C2000 mobile phone :
SOURCE: restriction code for lg c2000 cell phone
power off phone, put in sim card, power on, hit cancel key for invalid sim or secrity message, then put in restriction code 48570552 and hit enter key. your phone is ready for use. Have fun and live for free.
SOURCE: need Restriction Code
You will need to contact your service provider and request a "Subsidy Unlock Code". Other stipulations are involved with qualifying for a subsidy unlock, such as how long the line has been active, when the last subsidy unlock code was requested, and how long you've had the device. Usually these times are very short and you shouldnt have a problem. Just call your service provider. It sounds like the phone wasnt unlocked for that specific provider that you are usig
SOURCE: I need the restriction code for a LG c2000 cell
HI
A restriction code is numeric code (password) that prevents a user from accessing certain technical settings of a phone. It is specifically designed to prevent a phone from being reprogrammed to work with a different carrier (service provider).
This is what is usually meant when a phone is referred to as "locked". There are also "unlocked" phones that can be reprogrammed to work with a different carrier.
The reason for this system is the way phones are often sold. Many phones are sold below cost, (at a loss to the carrier,) with the expectation that the money will be recouped in the cost of the monthly service plan. The up-front loss that is later recouped is called a Subsidy.
For this to work financially for the carrier, the user must not buy the phone and then use it with a different carrier. The MSL makes that nearly impossible.
Unlocked phones are ususally much more expensive than locked phones, because there is no subsidy to offset the cost.
You should ask the operator for the restriction code
ENJO! RATE THIS SOLUTION
RNJ VINOD KUMAR
SOURCE: I NEED TO RESTRICTION CODE FOR MOBILE LG C2000
Hello, Restriction code is same like an unlock code they have same function and you can get lg c2000 unlock code from your network provider or you can buy lg unlock code from third party sites if you have tight budget.
