If you have changed these boards you need to first check your Va and Vs voltages, you should see a white paper listing the proper voltages, if you have a way of checking there are TP where you should put meter and get the proper voltage and also pots that you turn to change voltage. Make sure these are there first before continuing Bill.
The 42RV530U is known to develop problems in both the power board and the main board.
You can check out our power board repair service at
http://www.coppelltvrepair.com/p/442/repair-service-for-toshiba-42rv530u-power-board-75010942-dead-tv-or-clicking-on-and-off-problem
and I'd also recommend that you search for 42RV530U at http://blog.coppelltvrepair.com as we will eventually release an article on how to test the board.
Hope this helps.
I have a similar situation where the picture is gone on the TV, did you ever solve the problem ? and also if you don't mind, I would like to ask where did you find the boards. Thanks in advance.
