There may be a way to get to the audio and video without a remote by first pressing the menu button on the front of the set (if there is one), but the easiest fix is to invest in a good universal remote which will allow you to open the full TV menu. From the start up menu the remote will, after matching the code, allow you to go deeper into the start up menu to the audio/video menu and on to the "regular TV mode".
SOURCE: remote codes
Contact Direct tv and they should have the codes to program the remote tothat tv. Or contact Universal remote @ 919-573-7854 919-573-7854
SOURCE: codes for Philips 4 Device Universal Remote, Model US2-PM435S
Try this:
turn on the tv manually,then push and hold CODE SEARCH button until the red light stand still now release the button push and release the device button TV after that you got to push and release the ON/OFF button until the tv goes off stop.Now push the enter button to memorize the code check if the tv turn on with the remote.
You have to get some patience because you need to push the power button between 1 to 110 times.Good luck
SOURCE: remote code for magnavox tv using a zenith universal remote
Try looking for your code at:
http://www.oneforall-na.com/
SOURCE: Can't find Comcast remote code for Magnavox television 15MF605/17
Not every remote will control every TV. You basically have 3 options. 1) Call Comcast and see if they have additional codes not listed on their website/documentation 2) Call Magnavox and see if they have additional codes that might work with your remote. 3) Buy a 3rd party remote that works with both your comcast box and your television.
