HP 22"LE2201w Widescree LCD Monitor Logo
Anonymous Posted on Jan 28, 2011
Hello there is problem with my monitor LE2201W... there is lot of vertical and horizonyal lines in all colours mostly blue and dark red,picture is changing constantly,for second is OK after again blured with lot of lines,small letters is not possible to read only big letters. Can you give me advise,i am electronic engineer i have lot of tools and maybe i can change some of electronic components inside if you give me a clue
Anonymous
Level 3:
  • HP Master 6,771 Answers
  • Posted on Jan 28, 2011
Anonymous
HP Master
Level 3:
Answers
6771
Questions
0
Helped
1778018
Points
21413
There is a large board attached behind the LCD panel, the video enters and is processed on that board and distributed to the display screen, when there is a disruption in the processing it involves the panel that is tied to the main itself. If the video cable is detachable from the monitor and computer you can try to sub it for any change. Problems of this nature usually exceed the price of a new monitor and better just to replace it for a new one.
  • Anonymous Jan 28, 2011
    I assume you checked the computer with a spare monitor to rule out any issues.
Thin vertical colour lines on half of the screen
Hello, there is a problem with your monitors picture tube. May be it might have been damaged as a result of over power or even because of over use. Just try to change the picture tube or change your Monitor.
LCD display problem
Are you sure the cable is properly seated? You will typically get a tint of red green or blue when a particular pin on the cable isn't making contact. The lines on the other hand would indicate a bad display. Best advice would be to check the cable and if its all the way in hen replace the monitor. They are not worth repairing and also dangerous to work on.
Sky blue colour vertical line appear on the screen .
What is the problem with your monitor? Please give details on the problem of your monitor, this will guide me to suggest a solution to the problem.
Take care.
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Vertical lines in my laptop screen
Hi mikenstacy
Try to connect a normal desktop monitor to the laptop (there will be one vga port where you can connect the monitor) and if you see those lines on external monitor as well then most probably video card has gone bad (you can try to reinstall video drivers in this case) if those lilnes are not there on external monitor then problem is with your LCD so if system is in warranty then get it replaced other wise get in touch with local compter shop and get it replaced.
let me know if this helped
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
thats monitor problem dude, better go to the nearest repair center of your toshiba to assist you bout this problem.
2answers
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
