IF when the spa control calls for heat and it trips the breaker when the heater comes on then you have a bad heating element and it will need to be changed.
Disconnect the power to the spa. Disconnect the two wires going to the heater and then turn the spa back on.
If the spa stays running without the heater attached then that will be your source of trouble. New heater and you will be all fixed up.
