Why when i use master reset on my phone it restart and when it on back i can't see anything,then remove the batery and i on it back then i just see the word but not the picture!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!please help me!!!!!!!!!!!!!!!!!!!!!!!!!
Master Reset
Description: All configuration settings will be set back to their factory
defaults. Personal data and downloaded content will not be
lost.
From the standby screen, press Menu.
Scroll to and select Settings.
Scroll to and select Phone Settings.
Scroll to and select Reset Settings.
Select Master Reset.
Select Yes.
Enter Security code, then press OK. The default security code is 0000.
*Note: Do not remove the battery until the reset process is completely finished and the cellphone restarts or else it could damage the phone.
have you tried to restart your phone and then uninstall the program? if
it still does not work suggest that You could try backing everything up
and doing a master reset, but back everything up first (its so
important I said it twice). to do master reset just dial *#7370# and
accept. after the master reset you can restore your files by restoring
it from the back up.
send me your imei number and i will give you a master code. To check for your imei number, open the back cover of your phone and you will see it when you remove the batery. Your imei is also on your phone receipt.
This is usually the case when there is some kind of software corruption in the operating system. In this case, the device may need a master (in which all the data is erased). You will have to backup your phone if you are going to do a hard reset.
The other thing that might be worth doing is reinstalling the software with the CD provided in the pack.
If none of these work, then you'll have to take it to the service centre for repair
To master reset: go into the start menu, then system tools, and selecting master reset
Hello
You could try doing a master reset but you will lose all data / contacts /pictures/ on your phone
Steps to do a master reset
Settings/general/master reset/reset all/continue
Phone will restart
Darrin
try removing the external card if there is one and restart phone without it. if theres no external card, try master reset to factory settings and restart phone, please back up your contacts first before resetting your phone.
