gargling? describe the sound better my guess this is a fan or hard drive issue. stop using this until we are able to get the sound resolved. if the hard rive is making this noise it is about to give up the ghost and diegargling? describe the sound better my guess this is a fan or hard drive issue. stop using this until we are able to get the sound resolved. if the hard rive is making this noise it is about to give up the ghost and die
You can't post conmments that contain an email address.
sore throat , gargle with Benidine throat gargle
persistent throat irritation as in needing to clear the throat all the time , go see a specialist ear , nose and throat as it could be pollups in the voice muscles
Can be benign or cancerous so don't delay in making the appointment
Try connecting an antenna to the TV see if non cable reception is as bad. Or
Connect to a DVD player and see if sound is bad.
Could be audio amp on TV is bad.
Yes I have this type of washer and it has the water in a ring at the top of the drum to help balance it out during spin, not quite sure why but yes it should be there. The gargling sound you describe could also be the balancing hooks that attach the drum to the top of the washer which sometimes make strange noises but there fine.
during the monsoon the humidity buids fast on you coil there is a drain plug you can open or hook a piece of pipe from the drain plug that will solve the problem forever
The video cord from the screen to the motherboard plugin may be loose, check to make sure the cable plug is firmly plugged in, then remove and reseat back in place.
the noise is sometimes caused by dust in the volume control.
i would suggest blowing the dust out around the volume control if there is a manual control on the unit. use a small can of compressed air.. buy it at local walmart or computer store.
Gargled sound is nothing but it is unsupported applications with your leappy sound card.
But this is not true always.
first you check it by unstalling your sound driver and install it again.
if problem remains then your lappy is unsupported with those applications with gargled sound or corrupt if shows gargled sound with all applications.
you should try it with different working driver also.
