I would suggest swapping the consoles to see if the problem follows. If this does not help you figure it out, you are more than likely looking at a wiring issue.
this happen because lack of maintenance schedule, shut down and produce enough friction and loud, and shut down for to protect the electronic systemLUBE Inmediately the deck belt,maybe is time to replace the deck belt. by WORN. 2) LUBE THE rollers bearing too 3) test the motor voltage input, if there are the MOTOR need REPAIR.see my persosnal TIPS. God bless you
Switchthe power off without unplugging the machine. Do not take the safety key out ofits place.
Inspectthe bottom of your console. The calibration switch is in a small hole. Insertthe eraser end of a pencil into the hole and softly push the button. You willsee CL11 on your console after you push this button.
Usethe Speed + or - key to select MPH or KPH. Push the Power key to save yourselection.Sincerely.E.CUADRAMANAGUA, NICARAGUA C.A.
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike.
This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
The 6V battery will be within 12" from the pedals.
Additional reference:
Lifecycle Battery 0819-0012
Model
Description
Terminal
Volts
AH
L
W
H
Lbs
Price
0819-0012
Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006)
F2
6
2.5
4.48
1.81
2.75
$19.80
To get to the service menu start by pressing the pause button and keep it held down as you hit the clear button twice. The treadmill will reset and go into the service menu, and now you quite pressing the pause button.
This unit takes a special 6 volt battery. The battery is in one of two places. First place to look is under the unit. If you lay the bike over on its side there is an opening in the covers. If the battery is not there then you will need to take one of the side covers off. When you get the side off you cannot miss it. The battery is black with three cylinders. You can get the battery from sportsmith.net.
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
