Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jan 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I washed several loads of laundry yesterday. This morning I noticed water on the laundry room floor. I opened the door ( Whirlpool Duet Front-Loading) and water poured out on the floor. The tub of the washer was half full of water.
fgraef2
Level 2:
New Friend:
  • Expert 54 Answers
  • Posted on Jan 27, 2011
fgraef2
Expert
Level 2:
New Friend:
Answers
54
Questions
0
Helped
13045
Points
150
Make sure you drain lines are not plugged.
Whirlpool duet ghw9250 smells like burning rubber and very loud
Does the drum turn, if not then the drum bearings may have siezed.
1helpful
I getting a funky smell in my laundry room and bathroom, but only when I am doing laundry. I am wondering if it has something to do with the hose. Its be like this for about six months.Thanks
It probally mildew growing inside the wash tub and associated water connnections like the pump housing, drain hoses. Mildew growth is common problem with front load washers. You can try to reduce the occurance of mildew by leaving the door and soap dispenser door open when not in use. Also wipe with door gasket with a rag to dry it.
To kill the mildew in the machine wash an empty load with hot water and vineagar about once a month. Repeat as neccessary. There other products to help reduce mildew such as affresh. Hope this helps you.
Readout is flashing F35
Pressure switch issue. You will find it under a water level switch.
2answers
Drain
kathy..theres three screws at the bottom panel...remove them,,always unplug first...and you will see your pump claen your filter,,ok onthejob,,just screw it out
2helpful
Duet washer, water leaks out onto the floor, when not running.
warter seeping through valve remove power cord. them cut off water at wall remove 3 t20 screws from back of top panel slide panel toward rear to remove. remove hoses and electrical connections from valve remove 1 t15 srcew from back of rear panel to remove valve replace with part # 8181694 for about $50
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
2answers
Water fills up in machine when off
HI thanks for your question. i would replace the water valve, its not shutting off completly. replace the valve, thats where the hot & cold water go .
2answers
Whirlpool Duet GWH9100LW1 Frontloader problem
Found the tip on another thread of this site. Remove the 3 star screws located below the access panel that's below the door and clean the trap/filter to the left of the pump. Don't do like me and try to empty as much water first or you'll have an inch of water in your laundry roon when you twist off the cap.
Leaking door at the bottom
the vacuum which is to be created between the door and the tub must be not working......try cleaning the door ..some unwanted things may be blocking this to happen
Door is locked! Won't open! Laundry is stuck inside!
If the water has not completely emptied, this wont allow the door to open. Check by lowering the outlet hose into a bowl. If a fair amount of water comes the problem is likely to be a pump blockage
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
