Our phones have several buttons that I can't seem to program. I think these are dedicated as "feature access keys." When I press Feature > button, the display says "VACANT." The ones I can program (one touch keys) say "unused" when I do this. What is the difference? The manual says to program an feature access key, press Feature > redial > feature access key > desired feature access code. When I attempt this, I get "error" on the display. What I'm trying to do is to set these buttons to access voice mail, call forward, call forward cancel, and so forth. Two of the buttons are already programmed to "DND" and "MIC," but that was done before I got here. Thanks!
These Keys may be set as line keys instead of feature access or not tagged as "feature access" in the programming, also you can only have so many feature access keys... 8 comes to mind but I could be wrong, some features can be programmed permanently onto a button in the main programming so you can free up some more feature access (user programable) buttons.
Go to 7310 set you wish yo program leave handset on hook push feature star 3 then the button you wish to program then feature and
the code you want ex:feature 0 is speed dial that key will now be
programmed for speed dial. You cant program line keys or intercom keys.
Feature, Redial, press button to program, dial 1, dial the extension number, Feature to write and exit. ONLY IF the buttons are programmed as feature buttons, they may be just dead buttons, useless until they are assigned in system programming as feature buttons.
Can you please be a little more specific? Are you referring to assigning the paging feature to a button on the phone or programming the actions the system performs when you press the existing paging button on the phone? Normally, when you press the predefined paging button on this phone the system prompts you to select where your paging output goes. Depending on how your system was set up it may ask you to select "set", meaning when you select this soft-key the system will sound a short alert tone through all of the speakers in all of the phones connected to the system then allow you to talk through all of the phone set speakers. The other option is to select a soft-key that directs the output of the paging to an external PA system that is connected to the NAM through a punchblock connection. You can usually also select "both" which directs the output through the phone sets and the PA system. I am not certain what, if any system programming might be involved - I am fairly certain that if your system has not been connected to a PA system the paging function is just available to output through the phone set speakers. If your phones have no buttons assigned to the page feature then you'll need to refer to the system programming procedures to find out which feature code is assigned to paging and then access it by pressing FEATURE + the paging code or assigning the paging feature code to an unused button.
Press and hold the "f" for 8 seconds to access the remote programming features. The remote will emit one long beep and the LEDs will illuminate. Press the unlock button to access the remote programming features. Two transmit LEDs will flashes and two beeps indicate the remote programming features are accessed. Press the lock button on the remote( LED on indicates auto locking on, LED off indicates auto locking off). Press and release "f" button to exit programming.
Typically DND is turned on and off by pressing the FWD/DND button. There are three status conditions for this button indicated by the button light.
button light off: both features off(Forwarding and Do Not Disturb)
button light blinking red: Forwarding on
button light solid red: Do Not Disturb on
The functionality of this button can be customized by the phone system installer to work differently than outlined above. Station features can also be accessed through station programming using the LCD screen by pressing the button then either scrolling through the features using the LCD screen navigation keys or entering the specific program number as in 50 for FWD/DND programming.
Programming is done on M7310, M7324 and T7316 sets. To set up line appearence you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344. The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming. At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program the new lines on. Press the show key (top right arrow) The display should sat LINE ACCESS Press the show key (top right arrow) . The display should say LINE ASSIGNMENT. Press the show key (top right arrow) . The display ask for a line number. press list The display should say line 001: appear & ring press the next key (bottom right arrow) till it says 003:unaaign.
press the chng key till the screen says appear&ring Press the next key(bottom right arrow) The display should say line 004: unassign press the chng key til the screen says appear&ring
press the Rls key when finished
You need to program the feature "recall" on a button.
On the phone you want to program, press Feature 00 press a button you can program as "Recall" press feature 03 when finished, press feature 00 and you are done.
This phone can be access through a menu/ setting buttons.
Useful link on how to navigate through the phone: http://www.cisco.com/warp/public/779/largeent/avvid/products/7940/7940_topic3.htm
I think the main problem is to determine the intergrated router or Call manager configuration
You can also connect on switch and type:show cpd neighbor This will show the physical port connections
